Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
1/4 mile ET guesses????
Old Nov 7, 2007 | 04:28 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Ok so my car has been down pretty much all year cuz its been running like hell. Its an L98 Full bolt on car. It was running 13.52@102( GM High-Tech Performance Budget Bolton Shootout 3/07) 103*day.that was with a blown head gasket between # 3 and #5...lol. I have just added a ZZ4 cam and Brodix 200IK heads and replaced my stock injector (5 of which went bad from the car being in storage last winter) with 24lb injectors. and of course fixed the head gasket issue. So on a day with good air in say the 50's-60 temp range i'm hoping for mid-low 12's what do u guys think?! It had run 13.21@104 on cool days when it was just a full bolton car.
Old Nov 7, 2007 | 04:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 1/4 mile ET guesses????
well first off i think you could use 2800-3200 stall for best ET performance but not a big deal
heads and that cam with 1.6 rockers could be worth 25-30whp or more. I think mid high 12's isnt out of the question at probly 106mph. you'll need more launch to go better which comes from abit more stall speed
Old Nov 7, 2007 | 04:35 PM
Car: 89 Formula 350
if I only get 25-30HP from Brodix 200IK Heads a ZZ4 cam and replaced blown head gasket I burn the car in the driveway. A 70HP gain should be min.
Old Nov 7, 2007 | 04:54 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I guess i'm being conservative with it, i kinda read it wrong i thought you had the zz4 cam in when u ran 13.2 at 104. my bad.
that cam isnt all that huge but compared to the stock L98 cam its a nice mild step up. now that i think about it, i think the cam is worth 25whp over stock cam and with those heads i could believe another 30whp, so 50 at the wheels wouldnt be too far off. thats a good deal of power tho.
I made 254 and ran 12.9 at 103.8. local guy with a 408 stroker put down 308whp and ran mid high 12's at 110. and i'm lighter than his car. 50whp is a good increase.
think you'll be in the mid 12's at or near 108 mph. i'm gonna guess your near 300 whp with that setup with good tune
Old Nov 7, 2007 | 10:49 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
WIth slicks and more stall speed deep 12's should be no problem whatsoever. As is id expect it to do less then 12.5s. Seeing as you have a heads cammed SR'ed car with DR's
Old Nov 8, 2007 | 08:57 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
On a cool day prolly mid 12s.... My guess
chazman
Aug 28, 2018 03:25 PM
deracer
Apr 11, 2016 12:04 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
gta90
Sep 15, 2015 04:00 PM
chazman
Aug 22, 2015 02:01 PM
