new gears
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
new gears
I need a set of gears for my race car the 2.73's are holding me back im going to go with 4.11's i dont want to spend alot of money on the stock rear cause i have a 9 inch going in later on i just want to make sure that the carrier size i need is a 2 series i seen them on summit is there anything else i should know before i go and buy them just trying to make sure i get everything i need thanks.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: new gears
If your using the stock 2.73 carrier you will need a ring / pinion for a 2 series. the 2 series go up to 3.08 ratio`s and from there on out the 3 series. you can get a ring gear spacer and use a three series ring / pinion on a 2 series carrier, might be cheaper and better than running that super thick ring gear.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: new gears
And with the power you want to run I would use a 3.73 gear for strength. The 4.10 pinon gear is to small always seems to break.
Car: 1987 Trans Am
Engine: 355
Transmission: Th-400
Axle/Gears: 4.56 Richmond Gears
Re: new gears
I've got a very similar set p to his and I run a 4.56 gear and slicks with no problems. Well i did when this motor was in my 1980 Impala same thing except I had 1 3/4 primary long tubes and a mini spool, but same gear same carrier, heavier car, and slicks never broke anything. But i didn't hook up well in second gear, and I had a lot less stall so initial take off was dead. Comes down to whether or not you want to drive it much, if you aren't gonna get it out on the highway or drive consistently much over 60 then go low, but if you wanna drive it do 3.73.
Car: 1987 Trans Am
Engine: 355
Re: new gears
Yeah, but not mine for some reason. I know it is all original, my aunt bought it brand new, it had a 305 4 barrel, with 416 heads and a factory aluminum intake. IT only had like 50,000 miles on it when I got it. I found the build sheet under the back seat and it came with a 2.41 rear gear stock, according to everything I could find it should have been an 8.5, but it had 26 spline axles, open diff, and a 2.41 gear. I never had any problems with it before, but I probably wasn't pushin enough power to break anything.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
