Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Harmonic Balancer
Old Jan 10, 2008 | 01:12 AM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Harmonic Balancer
I am using a 400sbc with a stock balancer right now. I went on summit racings website and picked my motor then externally balanced. After that it says to pick a neutral balance or 26oz imbalance and I have no clue which one. The flexplate has the weight on it so do I use the neutral one or do I use the 26oz one to make the extarnal balance on both sides? I have no clue what to pick.
Old Jan 10, 2008 | 01:58 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Harmonic Balancer
Does your stock balancer have a weight on the inside ring? looking from the back of the balancer.
Old Jan 10, 2008 | 02:02 AM
Engine: 406sbc
Transmission: TH400
I dont think so. It's got the chunk "missing" of the inertia ring though. I dont think it has any weights inside it.
Old Jan 10, 2008 | 08:12 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Is the crankshaft in the engine internal or externally balanced?
Old Jan 10, 2008 | 09:38 AM
Engine: 406sbc
Transmission: TH400
Externally balanced
Like I said before, once I selected externally balanced it led to to picking a neutral balance one or a 26oz imbalance one. Either one could work but only one is right and I cant figure it out.
Old Jan 10, 2008 | 07:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
An externally balanced crankshaft can't use a neutrally balanced damper and flexplate/flywheel.
If you use a neutrally balanced damper, the engine will have a terrible vibration and will eventually destroy itself. Buy a damper for an externally balanced 400/383
Old Jan 10, 2008 | 07:18 PM
Engine: 406sbc
Transmission: TH400
I know it will but summit offers those both for a externally balanced motor
Old Jan 10, 2008 | 07:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Then you better call Summit and ask them. My guess is that if you choose a neutrally balanced damper, you'll get an internally balanced crank.
Old Jan 13, 2008 | 02:35 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
if your engine is a factory balance then it will use the 28oz weight. if the rotating assembly was balanced by you or a machine shop, then it could go either way depending on the crank and who balanced it.
Old Jan 13, 2008 | 09:59 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Machine shop balance has nothing to do with internal or externally balanced. A machine shop can't take an externally balanced crank and make it internally balanced.
Old Jan 13, 2008 | 10:37 AM
Engine: 406sbc
Transmission: TH400
I was just thinking that when I read it but kept my mouth shut since I'm not a pro. I think I need the 26oz imbalance one. I just put a stock one on with timing tape and I'll deal with it for now.
Old Jan 13, 2008 | 01:22 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
True but aftermarket cranks can go either way. Thats what I was suggesting.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
