8pt roll bar door bar location
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
is their a ihra rule about door bar location. i know that the bar that runs between the main hoop cant be 6 inches above or below the drivers shoulders (where the shoulder straps on a 5pt harness would attach) but is there a rule about door bar location? i think i remember seeing something about it somewhere and i searched but couldnt get anything.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 8pt roll bar door bar location
The door bar must pass between your shoulder and elbow.
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
oh ok good, because i sat the door boor in the position between my elbow and shoulders with my hands on the wheel and their was no way i was gonna get in and out of that thing at 6ft and 280 lbs lol thanxs again
Car: 87 IROC L98
I slide over an X door bar. When I had a stock steering wheel with tilt, it wasn't too bad. When I stripped it down into a non tilt column, I couldn't get in or out. A removable steering wheel solved the problem.
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
geez, how big are you stephen, i dont think my head could slide in their lol. id have to roll my window down and "bo duke" that bad boy.
Car: 87 IROC L98
The window net comes down when I'm not in the car
Dialed_In
Aug 20, 2015 01:45 PM
