Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Timing gears?
Old Jan 28, 2008 | 02:33 PM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Timing gears?
I have a set of pete jackson timing gears but I heard a lot of bad things about them lately. Are they really bad and I should avoid them? What would you guys suggest for a timing chain? Its a custom ground compcams retrofit Hyd. roller cam.
Old Jan 28, 2008 | 02:51 PM
Engine: 406sbc
Transmission: TH400
Re: Timing gears?
I did a search on here, bot others told me it causes premature wear on the cam and valavetrain and will cause premature valve float?
Old Jan 28, 2008 | 06:00 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: Timing gears?
I have no personal experience with gear drives but after all the strange stories why not stick with what is tried and true? You really can't go wrong with a "true roller" timing chain set. I've used the Summit brand one on a few builds and never had a problem. They're only like $32 too.
Old Jan 28, 2008 | 06:31 PM
Engine: 406sbc
Transmission: TH400
Re: Timing gears?
Thats why I am a little leary about it, I dont see too many people with them esp. in racing so I figured I would ask. I was going to get the Compcams magnum double roller timing set. I'm going to call Comp tomorrow to see what they suggest for the cam.
Old Jan 28, 2008 | 07:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Timing gears?
I had a set of noisy gears in my engine for one weekend then yanked them out and put a chain back in. Even in my race car they were too noisy.
Old Jan 28, 2008 | 07:19 PM
Engine: 406sbc
Transmission: TH400
Re: Timing gears?
What do you run now? Hear anything about the Cloyes hex adjust timing set?
Old Jan 28, 2008 | 07:22 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Timing gears?
I have the comp 3 way adjustable double roller timing chain that I had on my camaro for 300 miles that i'd sell for half of new if interested. I swapped to a hex adjust setup for my next combo.
Old Jan 28, 2008 | 07:36 PM
Engine: 406sbc
Transmission: TH400
Re: Timing gears?
I think I'm going to swap to a hex adjust when I put the cam in. Along with a 2pc Timing cover.
eightsixseven
Dec 16, 2024 01:50 PM
junkcltr
Aug 2, 2019 11:12 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
86White_T/A305
Aug 17, 2015 12:16 AM
