Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
1/8 Mile E.T Estimate
Old Mar 27, 2008 | 10:23 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
My car is a 1982 trans am with a 305 out of a 80s chevy 1/2 ton pick-up. it has a Edelbrock EPS performer intake, 600 Edelbrock carb, MSD HEI streetfire distributor, Flowtech 1 1/2 shorty headers, 2 1/2" single exhaust with a flowmaster 40 series muffler, Moroso solid motor and trans mounts. It has a borg-warner T-10 4-speed trans with 3.23 rear end gears, it has Lakewood LCA, lakewood 50/50 drag shocks, Edelbrock control arm relocation brackets, Edelbrock torque arm, Edelbrock panhard bar.
The battery is mounted it the trunk?
Old Mar 28, 2008 | 03:39 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: 1/8 Mile E.T Estimate
High 15's in the quarter, not to sure what that comes out to in the 1/8.
Old Mar 28, 2008 | 03:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Castlegar ? Cool.
What an oddball combination of parts you've got going there eh?
The 4 speed for 1982 Borg warner is actually the T-10, not the M24. Assuming that first gear is left and FORWARD, not back, correct?
I agree with that time guess. Your mods don't really add any horsepower, maybe 10-20HP at the most, with a barebones 140HP 305 you might be looking at 160HP optimistically.
Old Mar 28, 2008 | 04:00 PM
ljnowell's Avatar
Originally Posted by RK82
My car is a 1982 trans am with a 305 out of a 80s chevy 1/2 ton pick-up. it has a Edelbrock EPS performer intake, 600 Edelbrock carb, Edelbrock 1" 4-hole carb spacer, Holley 80gph fuel pump, MSD HEI streetfire distributor, Flowtech 1 1/2 shorty headers, 2 1/2" single exhaust with a flowmaster 40 series muffler exiting before the rear wheels, Moroso solid motor and trans mounts. It has a borg-warner 4-speed trans with 3.08 rear end gears, it has Lakewood LCA, lakewood 50/50 drag shocks, Edelbrock control arm relocation brackets, Edelbrock torque arm.
The battery is mounted it the trunk and the front sway bar has been removed?
Basically what you have is a stock truck engine, with stock truck heads, with a shiney stock replacement aluminum manifold. On top of that you have a carb that performs a little worse than stock. Spacer is worth nothing on this setup, IMO. Spark probably isnt an issue on an engine of this RPM range anyway, but I am sure the dizzy is pretty. The headers are not the best, but still better than manifolds. The exhaust is pretty much a stock piece though, to be honest. Minus cat with more noise. The suspension stuff would help, if the car had a traction problem anyway. I would guess high 15s low 16s.
Old Mar 29, 2008 | 09:24 AM
89ROCDROPTOP's Avatar
Car: 89IROC conv
Engine: LB9
Axle/Gears: 3.73 posi
I ran my bone stock IROC vert last summer. With a full tank of gas, I had a 15.92@85 mph. my 1/8 time was 10.1440 with a 2.27 60" time. A couple low 16 passes were mid to low 10's for the 8th. No mods what so ever, still has the original exhaust on it.
Old Mar 29, 2008 | 02:26 PM
danandamy's Avatar
Car: 86 Camaro
My guess: 10.34 in the 1/8.
Don't be discouraged, take it to the track on street night and find out. Get a good base line and start tinkering. Nothing more fun than adding parts and going back and seeing how much difference that part ACTUALLY made.
Good Luck
Dan
Old Sep 20, 2009 | 07:39 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
I finally made it out to a track, my best time was 10.47 at 68 MPH with a 2.494 60 foot, in the 1/8 mile, spinning bad through first and most of second
Old Sep 21, 2009 | 05:34 PM
danandamy's Avatar
Car: 86 Camaro
Dang, I was looking and thinking, 'I don't remember posting on this thread' then I looked at the date, it's been over a year! You really need to get out the track more often
Dan
Old May 14, 2010 | 10:21 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
I went out again last week, my best time was 10.04 at 71 MPH with a 2.33 60 foot, in the 1/8 mile. didn't really change anything except spark plugs.
Old May 15, 2010 | 11:17 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
man thats about where i was gonna guess. 10.00-10.10
Old Nov 21, 2011 | 08:47 PM
travis88iroc's Avatar
Car: Chevy Camaro IROC-Z
Engine: 5.7 350 c.i.
Axle/Gears: 9-bolt 3.70 ratio posi
well mine is the L98 350, ran a best of 9.36 at 74.32 mph and horrible reaction .3883 in the 8th! spinnin all night with bald tires
Old Nov 21, 2011 | 09:11 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Who said e3's don't make a lot more power.
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
skip91
Sep 24, 2015 03:29 PM
GouldyGTR
Sep 7, 2015 09:05 PM
