Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
most important things for getting these cars to hook
Old Apr 14, 2008 | 08:42 PM
84bandit's Avatar
so what can you do to get these cars to hook up?
subframe connectors and slicks i know
but im kidna lost past that on suspension parts
any help would be great
Old Apr 14, 2008 | 09:57 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Re: most important things for getting these cars to hook
For where your at, stickey tires-period.
Old Apr 15, 2008 | 10:08 PM
84bandit's Avatar
im looking at making about 450 at the crank with the turbo, so i need hook that a pair of slicks alone probably wont give me.
Old Apr 15, 2008 | 10:32 PM
IHI's Avatar
IHI
are you bracket racing or just looking for time slips?
i assume no bracket racing with a turbo, and if your just looking for a time slip:
slicks-450 at the crank sounds like alot but there are plenty of guys running completely stock suspensions (cept for the junk stock diff) running well into the 9's, your looking at high 11's, slicks are what you will need.
now if your bracket racing and need the timeslip to be the exact same pass after pass, lose the turbo, and then we'll get intot he nitty gritty of changes you can make, but no so much for hook, but more so getting newer tighter parts in there to minimize things flexing and causing a .00X and a few .00x there that will all add up to a ET chasing problem...but trust me, for now, stick with a BIAS PLY DOT or full race slick and you'll be fine.
Old Apr 16, 2008 | 05:39 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Take off your front sway bar if you have one, get some slicks, and see what happens... I've been 1.5x's on many occasions without any aftermarket suspension parts whatsoever... I wouldn't say my car is consistent but it'd usually hook. That's what makes it fun for me.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
midge54
Dec 27, 2019 04:14 PM
IroczFan
Oct 6, 2015 10:13 AM
stalkier
Aug 7, 2015 04:49 AM
