Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Any problems extending a rev limiter box wiring?
Old May 14, 2008 | 08:14 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have the MSD ajustable rev limiter box, it is too short on the wiring and i want to extend it 2 foot to remote mount it further, would that be a problem with its function?
Old May 16, 2008 | 01:09 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Any problems extending a rev limiter box wiring?
No problem that I know of, as long as you use the same size wire.
Old May 16, 2008 | 02:27 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Th wire i extended with is slightly larger, i was told if you use the same size or bigger it would be fine. We will deffinatly find out now.
Old May 16, 2008 | 08:00 AM
mean57's Avatar
Car: 87 gta
i called msd there response was if you need to splice use thicker wire.
this has no affect on any implied warranty.
Old May 16, 2008 | 01:41 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Awesome man, thanks. That eased some worry fore sure.
Old May 19, 2008 | 11:20 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I had to extend mine about 5' and i used same size wire as they come with, just be sure to get a good solder joint for maximum conductuity. Worst case scenario, it's off by 100rpm or so. I've had mine this way for 5 yrs and it's still going strong.
Old May 20, 2008 | 12:32 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Thanks man, i used the butt connectors AND soldered them so i would be sure to have a good connection.
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
perZ
Aug 15, 2015 01:17 PM
gta power
Aug 13, 2015 06:15 AM
