Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Another 1/4 mile estimate
Old May 14, 2008 | 11:34 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Should I atleast be able to hit 14's with this combo?
I bought the long block rebuilt 25,XXX ago and I swapped out the tbi for carb. It is a temporary motor till I finish gathering all the parts for the LS1 swap. I only paid $400 for the engine after I heard it run and then added the aftermarket.
355
191 heads ( I know, crappy heads)
Comp cam http://store.summitracing.com/partde...4&autoview=sku
Weiand 8024 dual plane intake
Holley double pumper 670cfm
Msd hei distributor
and the other mods in my sig.
Old May 15, 2008 | 03:11 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Another 1/4 mile estimate
Mid 14s sounds possible.
Old May 16, 2008 | 05:54 PM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
Cant see why low 14's arn't possible or possibly a high 13
my 385 runs low 13 high 12s
Old May 21, 2008 | 04:58 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I would be happy with anything under 14.9. My last couple of birds had lb9's and 700r4's and were running 15.4. I got this Formula and drove it for 2 days before the engine went so hopefully his engine is a decent performer.
Old May 21, 2008 | 05:56 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Man, it is so cheap to build a stroker motor that will carry one of theese to 13.00, bt for some like myself that isnt enough.
Old May 21, 2008 | 10:27 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
This is just a temporary motor till I do the LS1 swap next year. Otherwise I would build a stroker.
Old May 21, 2008 | 11:16 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Steve, I am looking for a buddy to go on a secret trip to the track when my car runs, you up for it maybe?
Old May 22, 2008 | 10:03 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Sure, let me know when and hopefully it'll be running.
Old Aug 2, 2008 | 09:22 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Ok, Engine and tranny are in with the mods in my sig and should be running this week. Any other thoughts? I'll be swapping in some 3.73's too.
Old Aug 5, 2008 | 04:48 PM
DPSJosh's Avatar
Car: 1987 Trans Am
Engine: Forged 383 with Brodix Heads
Transmission: Pro-Built TH400
Axle/Gears: 9-Bolt 4.11s with Posi
The heads/cam are going to kill you, but I would say with a decent 60ft, you could pull low 14's.
Old Aug 5, 2008 | 07:47 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I know the cam is small but I didn't want to push these crappy heads. If I can find a good deal on heads this winter while it's in the garage I'll buy them and a bigger cam.
83 Crossfire TA
Jan 3, 2016 01:26 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
86CamaroDan
Sep 29, 2015 10:08 PM
skip91
Sep 24, 2015 03:29 PM
bellez77
Sep 5, 2015 08:39 PM
