13s finally
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
13s finally
Ran a 13.91 on the first run and then two 13.88s @ 97 mph. The car has a Crane 2032 powermax cam and LT headers w/true duals. If anyone else is running a 13.8, could you post your time slip so I can compare it. This is the first time the car has run 13s with this setup, the egr valve was bad and causing all kinds of problems, finally figured out what it was and just put a block-off plate on there. So now that I have that figured out I can start working with timing, fuel pressure etc.. The car squats bad on launch also and has no sub-frame connectors so I need to remedy that. R/T .153, 60' 1.871, 330' 5.636, 1/8 8.808@77.02 mph, 1000' 11.561, 1/4 13.885@97.12 mph
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: 13s finally
Man, i remember a time when i wasnted to run 13s badly....now it is a quest for deep 10s.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 13s finally
what kind of tires you on? what gears? that 60 foot looks good for street tires and no converter. with converter and drag radials or slicks, you'll have a bottom 13 second car
here on of my runs back in the day with a stock TPI L98 with shorties, full exhaust, and 2800 stall on street tires with stock 2.77 gear. full suspension pretty much
my first 13 second run in cool spring air
1.89 60 foot
8.808 1/8 mile
77.18 mph 1/8 mile
11.56 1000 foot
13.89 at 96.6 mph 1/4 mile
i added slicks and 3.27 gears and went back in the summer heat
1.80 60 foot
8.72 1/8 at 76.96
11.48 1000 foot
13.79 at 96.77 1/4 mile
Cold november air, same setup as above but with 3.42 gears
1.75 60 foot
8.599 1/8 at 77.7 mph
11.33 1000 foot
13.63 at 96.9 mph
So you can see its only gonna get much better with better conditions and tires/converter. you have a cam and longtubes when i was bone stock internally and had shorties
1.89 60 foot
8.808 1/8 mile
77.18 mph 1/8 mile
11.56 1000 foot
1.80 60 foot
8.72 1/8 at 76.96
11.48 1000 foot
1.75 60 foot
11.33 1000 foot
13.63 at 96.9 mph
Re: 13s finally
Not quite 13.8, but I went 13.933 @ 97.78 at OSW in Orlando. The car had: !front sway bar, K&N's, gutted air boxes, BBK 52mm TB, MSD 6A & coil, TPIS wires, !smog pump, !cats, Magnaflow muffler, 3.73's, BMR CM LCA's, and J&M hotparts relo brackets. Tires were some dry rotted BFG drags mounted on the stock 16" wheels.
The 60' was 1.916 on that pass, 8.84 in the 1/8. The motor is internally, stock, stock 700R4 & converter, stock manifolds, etc.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 13s finally
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Re: 13s finally
Gears are 3.23, and those runs are on slicks. The next time I go out I am going to advance the timing and play with the fuel pressure. This was the first time I have been to the track in about a year, I wanted to see how it ran without the bad egr valve. Thanks for posting the times, I wanted to make sure my mph was right with my et.
Re: 13s finally
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: 13s finally
Well, if you were at higher elevation i would think it was normal. I just figgured it should go .2 quicker or so, was it summer time, i know te humidity is like Texas so a winter pass might net a couple of tenths.
Re: 13s finally
I'm going to swap back to factory gears, I did in my old car and picked up over a tenth. Next will be to rebuild the transmission, it likes to flare on upshifts. The car is no raggedy POS, but it's no spring chicken either, I'm a little over 100 miles away from 150K.
