Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
First Test and Tune
Old Jun 30, 2008 | 11:36 AM
87draggta's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: Th-400
Axle/Gears: 4.56 Richmond Gears
First Test and Tune
After finally getting my car back together I decided to take it to the track this past weekend and it wasn't pretty. My transmission slipped through all 3 gears until the third pass when I completely lost 3rd gear and coasted to a best of the night run of 9.35 at 67 mph with a 1.93 60ft. since my tranny is bad and i'm going to have to replace it anyway do you think I would be any better off running a turbo 350 instead of a 400?
Old Jun 30, 2008 | 04:05 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Re: First Test and Tune
I would stay with the 400 that way if you go up in HP later down the road you wont have to replace the 350 when that blows.
Old Jun 30, 2008 | 05:46 PM
87draggta's Avatar
Car: 1987 Trans Am
Engine: 355
I was thinking that would be the route to go, I am in the process of building a 421 as well. I'm having fuel pump problems as well which helped with the spectacular times.
Old Jun 30, 2008 | 07:04 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Whats the fuel pump problems?
Old Jul 1, 2008 | 11:01 AM
87draggta's Avatar
Car: 1987 Trans Am
Engine: 355
When I turn the key off all the fuel gets sucked out of the filter and while it is running there is air bubbles visible in the filter. I need a higher capacity fuel pump anyway the one I am using is a stock piece that I pulled off my 80 impala with a 305 so I'm sure at 6500 the pressure isn't optimal anyway
Old Jul 1, 2008 | 08:31 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
How can you see bubbles in the fuel filter? please tell you you dont run those ghetto inline clear plastic ones! Also you might want to upgrade to a better pump before racing it again, no sense in running out of fuel and breaking things.
Old Jul 2, 2008 | 06:52 AM
87draggta's Avatar
Car: 1987 Trans Am
Engine: 355
Yeah, I've got a clear plastic inline one, but I just used it because I had it lying around, I have a real filter in the fuel line though, my plastic one is there just because i like having two. I'll probably put a new pump on, but my priority is to get a transmission with more than 1 forward gear.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
R13_Braz
Sep 18, 2015 05:00 PM
