Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Second time out
Old Jul 6, 2008 | 04:05 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Second time out
Well, my first experience with the quarter mile didnt turn out so great. I ran a 17.4 @ 82mph and later discovered my timing to be way advanced, and my laun ch was horrible. My first run last night (second time out) turned out to be my new best. I ran a 15.86 @ 87 mph. I am driving a '91 GTA w/ LB9 305 and a 700R4. Much improvement over last time, but still I was hoping for mid to low 15's. Anywho, my 2nd and 3rd runs last night didnt turn out so well, I lost about half a second on both runs. Running 16.3 and 16.2. Anyone know why I would lose nearly half a second? My first launch was by far the best, but I wouldnt say the 2nd and 3rd launch's were that bad either. Oh well. I had a blast and can't wait to go out again.
Old Jul 6, 2008 | 05:15 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Re: Second time out
Your car should be faster than that. My friend had a 3.4L Grand prix that ran 15.90's?
I would give it a full tune up. Plugs, wires, check the timing again and all the settings, find out if it's spinning real bad. See if the Cat is clogged and just run through the whole list. I can't see it not running high 14's?
Good luck.
Old Jul 6, 2008 | 06:30 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Re: Second time out
Did you hot lap it or let it cool down between runs. My stock RS ran 16.6. You should be at least mid 15s. Some 3.42s would help.
Old Jul 7, 2008 | 10:28 PM
Shift06's Avatar
Re: Second time out
It's a near stock 305, I can't see it running 14's really, but yeah it had about 20 minutes between 1st and second run. It has new plugs, wires, cap and rotor, fresh rebuild, new magnaflow cat etc... :'(
Old Jul 8, 2008 | 05:10 PM
86 IROC's Avatar
Re: Second time out
What was the DA like? Track elevation? Maybe post the full slips for all 3 passes?
Old Jul 17, 2008 | 10:08 PM
Midniteson2's Avatar
Car: 1991 Firebird
Axle/Gears: 3.42 w/auburn racers diff
Re: Second time out
I would check the cat or cats on your car and make sure they are not plugged up. My cars cat was plugged, cut it off and put on a fresh set of tires on the back, and went from 16.7 to 15.9s
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
