Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Just another what will it run question.... :/
Old Oct 18, 2008 | 08:17 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
Ok, some are probably bored of this kind of questions and I understand that but I am curious and my TA wont be completed untill next spring.
Its 86 TA with:
ZZ383 425hp/440 tq engine (from GM Performance)
Edelbrock Performer rpm dual plane intake (so probably little less hp and more tq at lower end),
SMI Stage 2 Q-jet carb,
MSD ignition, MSD 6AL,
Hooker 2210, Single Mufflex 4 inch exhaust (no cat)
TH700R4 Raptor (for engines up to 600 hp/600 tq), 2500 rpm stall
9 inch Ford with 3.50 and True Track
275/40/17 drag radials at back
And lot of other stuff that doesnt matter for 1/4 mile (like UMI subframe connector, Wonderbar, etc etc).
I had been aiming at mid to high 12s but that whas without drag radials.
What should I expect with my combo (and the drag radials)?
Old Oct 18, 2008 | 08:51 PM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Re: Just another what will it run question.... :/
I'm gonna say low 13's, maybe high 12's. Gotta remember that motor only puts like 375ish to the wheels.
Old Oct 19, 2008 | 08:10 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
I sure hope it will be better than low 13´s. I think it was Chevy High Performance who put this engine in Nova with dual plane intake, 4.10, 3000 stall and the got in the 11´s.
Old Oct 19, 2008 | 10:24 AM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
12's should be easy.
375 to the wheels is good for 11's there buddy. My car runs mid-low 12's and has what I'd guess to be around 330 at the wheels.
Old Oct 19, 2008 | 11:12 AM
Engine: 406sbc
Transmission: TH400
I just took a stab at it, I've seen a bunch of 350+hp cars go high 12's lately, I guess its all dependant on traction and suspension.
Old Oct 20, 2008 | 08:10 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
I thought so, I had been hoping for mid to high 12´s but now I hope low 12´s (because of the drag radials).
Old Oct 29, 2008 | 10:07 PM
DPSJosh's Avatar
Car: 1987 Trans Am
Engine: Forged 383 with Brodix Heads
Transmission: Pro-Built TH400
Axle/Gears: 9-Bolt 4.11s with Posi
I'd say it will go mid 12's depending on weight and how well it leaves.
Old Oct 30, 2008 | 10:01 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
The stall on the converter is a little low. You are good for mid to high 12's. With a higher stall converter you might get high 11's on a good launch
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
