Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Ignition box mounting
Old Feb 10, 2009 | 08:58 PM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
I finally picked up a 6AL for the car, been sitting for 4 months now. I mounted it on the firewall where my AC box used to be. I was told that theres too much heat there and to move it. Is this person correct? I dont mind moving it if i'll keep the box alive longer.
My question is where do you have yours mounted? Pics? Also is the person right about the heat? I have 2210's ceramic coated.
Any help would be appreciated..
Old Feb 10, 2009 | 10:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Ignition box mounting
If the headers are coated, the amount of under hood heat is much lower. Mine is a gutted out race car. My ignition and coil are inside the car.
Old Feb 10, 2009 | 11:46 PM
skinny z's Avatar
I made a mounting pad out of aluminum flat stock and installed it over the charcoal canister. Even managed to use factory only bolt holes.
Old Feb 11, 2009 | 12:04 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
very clean install
:thread content:
ive got a accel 300+ ign setup and ive got the box mounted above the relays on the firewall inbtween the brake booster and fender
works and looks good
Old Feb 11, 2009 | 09:49 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Mine sits on the driver's side firewall in the corner. It's been there for about 6 years now, never gets wet or even remotely hot.
Old Feb 11, 2009 | 10:58 AM
Engine: 406sbc
Transmission: TH400
Thanks guys!
Skinny that setup looks nice, I think I'm going to move mine there. I have a good idea for somewhere to install it inside the car so I'll see if that works 1st.
Old Feb 11, 2009 | 06:00 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
this sits right up where the passengers feet would normally go....Just take out the seat, no one will ever ask for a ride again!!
Old Feb 11, 2009 | 06:03 PM
skinny z's Avatar
[QUOTE=greezemonkey;4040222]this sits right up where the passengers feet would normally go....Just take out the seat, no one will ever ask for a ride again!!
QUOTE]
Nice!
Old Feb 28, 2009 | 06:04 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
when i had a stock dash, i used a modified factory computer bracket to house the msd under the dash inside the car.
now that i have a 4th gen dash, i have it mounted on the back of the glovebox, so its accessable, and still able to use the glove box.
i dont have any pics or id post them.
Old Mar 1, 2009 | 01:24 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
this has been covered before....
here is mine...its the digital so i can adjust from inside the car.....well?...when I had the car.......but thats a different story..
i usually have the kick panel on so you cant see the wires at all
Old Mar 1, 2009 | 02:46 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
Stage20 and I must have done the same thing.
Old Mar 1, 2009 | 03:11 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i had a sheet of abs plastic over it, but same effect.
looks good!!
BRoss99
Aug 10, 2025 05:08 PM
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
