Rear Sway Bar..
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Rear Sway Bar..
Who's running a factory rear sway bar? & is anyone running a welded in "Drag Sway Bar"
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear Sway Bar..
Rear anti roll bar. I have an aftermarket weld in one. I use one of these. It can be custom fit into just about anything. For a third gen however with all it's sheet metal framework, you will need something more structural to weld it to.
http://www.d-mproducts.com/antirollbars.htm
It made launching the car so straight I can almost let go of the steering wheel when the transbrake releases.
Re: Rear Sway Bar..
I have a rear anti roll bar, similar to whats on tube chassis cars mounted above the rear axle, and I must say usually the car goes real straight.....which is good when the front tires are way off the ground
Re: Rear Sway Bar..
i have a wolfe, but if i didnt have a factory fuel tank i would run a chassis mounted one.
if your in the mid 11's or faster i'd say its a must have. its a night and day difference.
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: Rear Sway Bar..
1.28 from 1.5`s here with a rear end mounted wolfe PLUS dead even launches, maybe one of the best things Ive added
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Re: Rear Sway Bar..
i'm currently running a stock IROC bar with poly bushings everywhere. i'm going to shorten the drivers side endlink spacer for now, along with my pass side air bag. i'll get a real anti-roll bar later. i still street drive my car and i'm not sure i want to tie the rear of the car down like that.
i'm impressed with all these big power cars improvements though! i'm hoping to be in the 1.5x range when i get the car back together, but i'm wondering now if i'm leaving some on the table.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Rear Sway Bar..
Looks good, I'll prob..y get the Wolf kit.
What is the double sway bar link kit all about ?
Re: Rear Sway Bar..
Got mine, just need to finish welding the rest of it.
Re: Rear Sway Bar..
My concern is the hiem joint sleeve doesn't "rest" straight up & down, its kinda angled, there just wasnt enough material on the frame to get a good solid spot to weld the plate to, so we placed it about 1" forward.
The tabs on the diff tube are welded at an 11 o'clock position, as per Dan @ Wolf, and it looks like its ready for duty.
Re: Rear Sway Bar..
Its called a drag bar, so I dont think its a street friendly part, but you're car is almost un-streetable anyway so.... Lets put one in!
$400 parts, $200 labor
call me
call me
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Engine: 7.0L
Re: Rear Sway Bar..
Take a look at team Zs part also.
http://www.trzmotorsports.com/34f.html#rear
now that is cool.
Re: Rear Sway Bar..
Its not as close as it looks.
Car: 87 IROC L98
Re: Rear Sway Bar..
Because my mounts are on the diff back brace, they're not exactly in the same position on either side. One is a bit forward of the other and I have no problems.
ProtoMaster22
Aug 26, 2015 07:50 AM
