Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Would this work? Just a thought
Old Apr 2, 2009 | 07:24 PM
GFR88IROCZ's Avatar
Car: 86 Sport Coupe
Engine: LG4
Transmission: BW 5 speed
Have a spare line lock. Put it on the hydraulic clutch line. depress clutch flip switch. and when light goes green release switch to drop clutch. just a thought.
Old Apr 2, 2009 | 07:27 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: Would this work? Just a thought
In theory, it should work. I wouldn't advise doing it
Old Apr 2, 2009 | 07:57 PM
GFR88IROCZ's Avatar
Car: 86 Sport Coupe
Engine: LG4
would it be too much of a shock on the clutch? or release too slow?
Old Apr 2, 2009 | 09:48 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
good question.....Pressure shouldn't be an issue and no real different than guys who "side-step" the clutch. Now just have to find out if that T5 will hold up to the shock load......
Old Apr 3, 2009 | 12:10 AM
87_TA's Avatar
What would be cool is if you could use a progressive controller... Like nitrous controllers.. Of course you would probably have to burn up a clutch to get release perfect..
Old Apr 3, 2009 | 11:35 AM
kcb37's Avatar
That would be like side stepping the clutch.
It should work just fine. I just don't like the idea of the clutch being dumped like that. I know I come up real quick on mine, just about side stepping but not quite.
Kinda depends on where your foot would be too. If you for any reason the tires lost traction or the car started to go sideways your foot is already on the clutch and you can go back down to regain traction, or to regain control of the car and hopefully finish your pass.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
gta90
Sep 15, 2015 04:00 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
Leggman1
Aug 6, 2015 04:15 AM
