10" wheel - need pics. new guy here.
Wanting pics of 10" rear wheel need to know back spacing please. Currently running 8" with 5.5 bs and getting ready to upgrade. If you can post side profile pics would be great. Wanting to tuck (if you know what I mean).
Thanks, Scott
Thanks, Scott
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: 10" wheel - need pics. new guy here.
that's about the most backspacing you can run on these cars without getting crazy with cutting out the wheelwells. A 10" rim would look less tucked than your setup now by sticking out 2" further with a 5.5bs rim. I'm running 6.5bs but basically have a minitub on my car.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Most common backspacing for a 10" rim on a third gen is 5.5". It will really depend on the height/width of the tires you want to use because the backspacing will determine where they fit under the fenders.
Car: 87 IROC L98
Lots of room for a 28 x 10 slick. With a bunch of inner fender modifications, I was able to squeeze a 29.5 x 10.5 ET Drag under the fenders.
Depending what your current rpm range is and what rpm you're currently crossing the finish line at, going from a 26 to 28" tall tire will probably require a deeper gear in the diff.
I am assuming you're talking about a slick and not a DOT tire. The width is measured differently. A 10" DOT tire is 10" across the section of the tire. Tread will be less. A 10" slick is measured across the tread and the section width will be greater.
a 10" wheel on these cars with 5.5 bs looks disgusting. if you're dead set on 10" wheel get it with 6.5 bs and be prepared to do the necessary bfh stuff. Or just run a 9" wheel with 5.5 bs and be lazy like me
Car: 89 RS
Transmission: th350
I have a 10" wheel with a 5.5 bs. I have a 295/50/15 (10") on it now, I plan on going to a 275/50/15 (9") cause the tires on there now rub alittle.
Car: 87 GTA
I say the closer to center, or at least a DEEP dish on the outside, looks best. 6.5" bs would give it less of a dish.
Car: 87 IROC L98
15 x 10 rims with 5.5" backspacing. I think those tires were 28 x 10.
Same rims but 29.5 x 10.5 tires
Here's a 15 x 15 rim with 5.5" backspace
The diff is also almost 20" narrower.
Car: 92 L98 Z28 Heritage Hard Top
Engine: L98 350 w/ HSR,24lbs inj,AFPR
Transmission: TCI Super Street Fighter W/3300 sta
Axle/Gears: 3.73 Detriot NoSpin,LPW cover
If you want some good pics, search 295 DR's mounted, very good info on 10" wheel
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
here's mine, 29x9 hooser drag slick on a 15x10 with 6.5" backspacing. all i did was some BFH and cut the bumpstops out. i'm also running a 3/16" spacer. no rubbing.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
[IMG]
[/IMG]
In this picture this is a 275-60-15 drag radial with a Holeshot 15X10 wheel with 5 7/8 backspacing.
[/IMG]In this picture this is a 275-60-15 drag radial with a Holeshot 15X10 wheel with 5 7/8 backspacing.
1992rs/ss
Jan 31, 2025 05:10 PM
