Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Rotating vs static vs sprung and unsprung wt
Old Nov 7, 2009 | 07:29 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Some say every lb of rotating wt is equivalent to 6 lbs of static wt.
Does lowering sprung vs unsprung wt have the same effect on acceleration?
I've replaced the stock front rotors with an aluminum hub and 2 piece rotor, resulting in a wt loss of 14 lbs per side. Also going to wheels that are 2 lbs lighter per wheel.
So is this gonna help with lowering ET or is it wishfull thinking? I know wt loss is supposed to lower ET; just trying to quantify what I did.
Old Nov 7, 2009 | 08:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rotating vs static vs sprung and unsprung wt
Unsprung weight is dead weight. It can't be controlled by the shocks and springs. Since it can't be controlled, you want it as light as possible.
Lightweight tires and rims. Aluminum brake parts such as calipers and front hubs. Tubular a-arms. Aluminum components in a diff such as a spool and with a 9", the case and bearing support. A lightened ring gear can shave off a little more weight. With large diameter axles, gundrilled cuts down on weight.
Old Nov 8, 2009 | 08:43 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Sprung v unsprung weight is more of a handling issue then an acceleration issue.... The old equation is that a 1 lb. reduction of unsprung weight is equal to a 6 or 7 pound reduction in sprung weight...
The weight v acceleration concerns the overall weight of the car, a 100 lb. reduction equals a 1/10 sec. reduction in ET... Reducing weight in the rear end, as Stphen 87 stated, allows the components in the drivetrain to accelerate faster, therefore lowering your ET... Any reduction of the rotating mass in the engine and drivetrain will make for quicker acceleration.
Just keep in mind the basics of physics, an object at rest tends to stay at rest and the greater the mass (weight) the slower the rate of acceleration.... However, remember the other side of physics laws--an object in motion tends to stay in motion....so things like a 40lb. flywheel on a five speed car v a 20 pound aluminum flywheel, the heavy flywheel will help to keep the revs up when you shift.....
db057
Jan 10, 2020 08:55 PM
87v6Bird
Jul 1, 2018 04:12 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
camarohelp
Sep 22, 2015 03:19 PM
