Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Just curious what time should i be looking for?
Old Mar 23, 2010 | 07:30 PM
DerfPower509's Avatar
Car: 84 Z28 and a 95 Z28
Engine: Built 350 sixty over
Transmission: W/C T-5
Axle/Gears: 4:56s auburn posi, mosers, girdle
I have an 84 Z28 that i rebuilt from the ground up. I has a 350 .060 over comp cam 540 intake 558 exhaust solid flat tappet 252/260 at .050 113 heads, ported with 1.6 exhaust valves, full roller rockers 1.5 ratio, 11 to 1 compression ratio, single plane proffesional products hurricane intake, 750 holley double pumper, shorty headers, cut outs, turn it 7200 rpm. World Class T5 with centerforce DF, 4.56 rear gears, has moser axles and all the goods so hopefully wont break. UMI adjustable torque arm with crossmember, and some 26 inch tall slicks. Car sure is a hell of a lot of fun on the street Would appreciate any suggestions also. Thanks
Old Mar 23, 2010 | 07:39 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: Just curious what time should i be looking for?
i'd say low 12's so long as the t5 and rear diff stay together
Old Mar 23, 2010 | 09:43 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i don't see it making to the 330' marker with any real traction. t5 AND a 7.5" 10bolt with slicks and a stronger than stock clutch. something's gonna give, and i don't see it being the slicks OR the clutch.
Old Mar 23, 2010 | 10:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Providing the tranny or diff don't fail, low 12's should be obtainable.
Old Mar 25, 2010 | 09:09 PM
89lt1's Avatar
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
he has already gone 12.5 without launching spinning thru 1st w/ dr's
60' was 1.9
and mph was 112
Old Mar 25, 2010 | 11:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Well he asked for opinions and we gave them. If you really want to know what a car will run in the 1/4 mile, you take it to the track. Guesses are just that, guesses. Don't be disappointed if performance isn't what you expect. Everyone thinks they have a 12, 11, 10 second car until they get a timeslip that says otherwise.
Old Mar 26, 2010 | 11:46 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
60' was 1.9
and mph was 112
The key words to this is the no launch and spinning part....... This is what the guys are trying to say. Once the thing hooks maybe things will be better.... or maybe they will go BOOM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Wvcamaro
Sep 4, 2015 08:38 PM
redmaroz
Aug 16, 2015 11:40 PM
Randomtask2
Aug 13, 2015 01:57 AM
Jake_92RS
Aug 11, 2015 10:39 AM
