Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
first pass on new motor
Old May 15, 2010 | 02:09 PM
gtanut's Avatar
made it to the track last night made first pass on new set up went 11.92 @ 112 with a 1.93 60ft with no tunning at all then i had really bad oil pressure issue oil pressure went from 60 psi to zero back up yhen back down no noises or anything tried 2 different gauges same problem i dont think i hurt anything but i am going to pull motor and check just to be sure motor builder said he would warrenty any problems better safe than sorry i guess
Old May 15, 2010 | 04:35 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: first pass on new motor
How much & what visc oil? What type pressure gauge?
I've heard that mech gauges with a big enough line will show every fluctuation.
Are you running just enough oil to get thru the traps, or a thin visc like straight 20 wt?
Agreed, better safe than sorry.
Good luck
Old May 15, 2010 | 04:55 PM
gtanut's Avatar
i actually have hooked 2 different gauges up 1 electric and 1 mech oil i am running is royal purple 10w30 6 1/2 quarts i would think that if it were a bad pump it would have little to no pressure all the time
Old May 15, 2010 | 05:01 PM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
the pick up probably fell off
Old May 15, 2010 | 08:14 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
The pump may have come loose. Internal oil leak. Seen it before.
Old May 16, 2010 | 07:39 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
what are the specs on the motor. Thats seems pretty stout for a bad 60 ft time
Old May 16, 2010 | 08:06 PM
gtanut's Avatar
its a bbc
69 Six Pack
Oct 5, 2015 07:51 PM
Cacike
Aug 27, 2015 05:10 PM
Randomtask2
Aug 26, 2015 03:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
wruiz
Aug 11, 2015 02:59 PM
