a quick update on the camaro
Re: a quick update on the camaro
be careful with custom "special" lobes some of these guys are having ground for people.... i know of at least one guy that was selling cams with a lobe that was more radical than the ones used in a sprint car camshaft. (short duration racing)
basically those guys were killing the valvesprings by 1-2k miles or so and were floating the valves, among other things. same thing every time... they would install the cam/springs, take it to the dyno, lay down some nice #s, and then trouble shortly thereafter. radical lobes are good for making power, but there is always a downside. i would make sure to get a copy of the cam card and make sure its not a retarded lobe design.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
these cams are actually EASIER on the valvetrain than some of the ones out there for ls based motors that other shops put out. Not uncommon to get 10k out of a set of springs with these lobes with patriot extreme dual valvesprings setup properly. I also have a cam doctor from the shop of the cam specs and it isn't crazy at all, just makes a lot of under the curve total power instead of a peaky cam like the majority of the big grinds out there.
its the new thing, so it costs more. sorta like the "corvette tax". they've been poppin' out sbc cams for 50 years now.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i'll still need cam specs before i buy, and before i have a converter built for the th400 i'm putting together this winter.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
But yeah you will want to know the specs to get an idea of where your torque curve will be. That is needed to spec the converter.
just got my new cam for the blown combo, it's a baby...lol 288/302 @ .050, .802/.790, 114ls we may need more duration, but we'll see. I'm planning to turn this thing around 9600 out the back.
db057
Aug 11, 2015 10:11 PM
