Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
E85 to race?
Old Sep 12, 2010 | 08:47 PM
overdriv's Avatar
E85 to race?
Are any of you guys running on E85 or higher? If so, I'm looking for a supplier in central IL of E98.
Old Sep 14, 2010 | 10:29 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: E85 to race?
there is a local guy (Eddyville Raceway in Iowa) that runs e85 with good success, and another that runs it with his procharged nova. both cars run 6.0x or faster and dead consistent. what questions exactly do you have?
Old Sep 18, 2010 | 08:15 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: E85 to race?
I run E85 in a 2840 lb car. 406 sbc , 6.32 to 6.38 with 60s in the 1.32 to 1.38 in the summer heat and marginal track. Haven't been out much this year early then had a heart attack little over a month ago. Hope to get out before the season is over. I'm very happy with the switch to E85 and would do it again. I was having trouble sooting my plugs on race gas, usually indicating rich, but when I took fuel it slowed down. The plugs on corn are clean as can be. Won't be going back to gas.
Old Sep 24, 2010 | 09:02 AM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
Re: E85 to race?
i run E85 and it is great stuff. it is consistant. and i use nitrous with it
Old Sep 24, 2010 | 09:30 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Re: E85 to race?
stiletto, did you have your system flowed or what adjustments did you have to make for the tune ups from gas?
Old Sep 24, 2010 | 09:41 AM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Re: E85 to race?
i had a quick fuel Q850 for gas, then i bought the metering blocks from them and jetted up and adjusted the floats and fuel regulator.
i have a aerospace ultra 350 pump and #10 fuel line. i didnt have anyhting flowed.
Old Sep 24, 2010 | 01:41 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Re: E85 to race?
i was meaning on the nitrous side of things
Old Sep 24, 2010 | 01:44 PM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Re: E85 to race?
i was at 5 3/4 psi on gas and i just set it at 7 psi on E85 and then made passes and read plugs, gotta read the plugs carefully
Old Sep 24, 2010 | 06:09 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Re: E85 to race?
i know, e85 burns so so clean seeing a fuel ring would be pretty difficult....i wouldn't imagine that reading the timing would change that much
Old Sep 27, 2010 | 03:25 PM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Re: E85 to race?
Reading the timing is still the same, just the fuel is a little more difficult to read
Old Sep 27, 2010 | 06:30 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Re: E85 to race?
Do you have to do anything special to the fuel system to run E85/E98. I have a virgin fuel system(no gas in the tank yet)that consists of all aeromotive pump and filters to stainless braided lines. I have a station that sells E85 from the pump just a few miles away. That would be nice if I could run it with out to much trouble.
Old Sep 27, 2010 | 09:32 PM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Re: E85 to race?
what aeromotive pump you got? set it up like you gonna run alcohol.If all of you components are alcohol compatable then you good to go. Yes you will have to have you carb set up for it. Call Zack at quick fuel!!!!!
Old Sep 28, 2010 | 10:43 AM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Re: E85 to race?
I have an A1000 pump. Factory tank that is sumped with a Comp Engineering sump and I'm running EFI with a HSR manifold and 65# injectors. I was told that E85 is very corrosive and that I would need to have me tank coated, any truth to this?
Old Sep 29, 2010 | 07:40 AM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Re: E85 to race?
its slightly corrosive, i add VP fuels alcohol additive to solve that.
i believe an A1000 will work.
i have noticed that sometimes the needle below the squirter will get stuck if the car sits for a month or more
Old Sep 29, 2010 | 11:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
E85 is not corrosive like methanol. Keep water out of it, and you won't have any problems.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
