How competitive are 3rd gens in Auto X
Car: 1989 Camaro RS
Engine: TBI 305 STOCK
Transmission: 700r
Axle/Gears: 2.73?
My friend with a prelude at school invited me to an autocross event on the 27th
My car is bone stock with 305tbi 700r auto and im wondering how it will do in autocross.
From what i have heard these cars tend to do well and from what i feel it should do okay but just want some advice
And for this first race i want it stock however im wonderign what my first mod should be a subrfame connector? ( i was also wondering if these subframe connectors affected work space?)
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: How competitive are 3rd gens in Auto X
Tires and sub-frame connectors are a good starting point. If you really are interested in the sport than I'd suggest looking at an aftermarket suspension.
Car: 1989 Camaro RS
Transmission: 700r
Axle/Gears: 2.73?
Yeah thats what i hear so i am assuming they can do good?
for my first go im going all stock
and i think autocross is the way i am leaning with my car because lots of people do drag cars and its different
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Well, the asians i have seen over seas use them in videos.
http://www.youtube.com/watch?v=RX8X5AJao6Y
http://www.youtube.com/watch?v=r1bI7PZdmG4
http://www.youtube.com/watch?v=BKSYsr421aY
Heres a shot of the underside of my 85 Z28, that I am building for Autocross/street car. Basicly I just want a really good handling street car that I can have fun with at an autocross event. Lots of time and $ in suspension mods here......hope this gives you some ideas.......
Car: 87 IROC
Engine: LB9
Axle/Gears: 3.70 9 bolt
Depending on the subframe connectors that you install you could end up in a class where you wouldn't be competitive at all. Make sure you thoroughly go through all the class rules before doing any mods.
~Matt
~Matt
Car: 87 GTA
SFCs will bump you up so far into a class that unless you have a LOT more mods & are a really good driver? You'll get slaughtered on course. They aren't needed to run & you can still have a lot of fun without them.
3rd gens handle really great for autocross. Auto trannies can be tricky to drive on a course, when the tranny is trying to downshift for itself in a tight turn or under hard acceleration.
Car: 1989 Camaro RS
Transmission: 700r
Axle/Gears: 2.73?
Thanks unpredictable your car looks really nice im planning on some suspension mods like those eventually
and 88ws6
Yeah im going completely stock the first time and depending how that goes will depend what i do
I think ill also look at the class rules and make sure every next mod i do will keep me novice
thanks
and 88ws6
thanks
Car: 87 GTA
http://cms.scca.com/documents/2011%2...lo%20Rules.pdf
Your local club may have a local class that allows more typical street mods on a car that doesn't put it into Modified Class. I know my local club has one, that allows stuff like SFCs, yet doesn't put the car into Modified.
Last edited by Stephen; Feb 8, 2011 at 09:23 AM. Reason: Changed the link to the 2011 rules.....
Car: 1989 Camaro RS
Transmission: 700r
Axle/Gears: 2.73?
Mine is in the stock class cause the only mod i did was a chrome air cleaner.
However it does say i can replace my bushings and i think im going to do that and that only before
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Looks like the same parts i have except no dual exhaust, i have CE sub frames and they help at the drag strip. I dont know jack about auto x though.
Car: 87 GTA
13.10.A. The engine air filter element may be removed or replaced provided the air flow path remains as originally designed (i.e., no additional openings). No other components of the air induction system may be removed, replaced, or modified.
Your chrome air cleaner puts you in Street Prepared:
15.10.E. Air cleaner(s) may be changed or removed, velocity stacks may be added.
First time out I would suggest you leave it all stock, just replace anything that is worn, loose or broken. Just register as "non-competition" (in other words, you're out there to have fun/learn, not in for the points race), or stock (is it still f-stock?)...
Is your TBI car a z28/Iroc/TA/GTA/Formula? I believe even some of the base models got good suspensions with the right options, but one of the performance models could be quite competitive the way it came from the factory. Similar condition setup with a similar driver any decent 3rd gen should be faster then a Prelude, but for the most part, the driver will make a bigger difference WRT to times then the car.
Anyway, after getting out there and getting a good handle on it if you get bit by the bug you may decide that you want to run one of the stock classes, so spending money on most mods before hand would be a waste. Typically if you start doing some of the stuff that gets you into the prepared classes you have to have a pretty serious setup and know what you're doing to be competitive again, so I wouldn't suggest that for beginners.
Car: 1989 Camaro RS
Transmission: 700r
Axle/Gears: 2.73?
Alright thanks ill throw my stock air cleaner back on their
but mine is just and RS and supposedly F stock class because it says v8 camaros
However ill just do the non competition all stock and see how i do
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I just signed up today for a novice autocross course in my area... I'm not looking to compete, I've done a lot of mods to my car suspension wise, and minor motor mods, headers, etc... I'm just lookin to have fun with my Firebird
Rafael
Rafael
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
This is going to sound odd to someone new to the sport, but the biggest mod for "stock" class is going to be R-compound tires.
Strangely enough, the street tire classes allow more suspension mods than stock class, but require street tires (with a tread wear rating of I think 140+).
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Best first mod and is legal in the stock class, Koni shocks and struts.
GMan, what kind of r-comps are F-stock legal? I didn't think A6's were ok until ESP?
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Car: 1991 Camaro B4C
If this is your first time autocrossing ever, don't worry about performance and mods. Just drive what you have and learn as much as possible your first time out. Be humble: there will probably be people there in tiny Hondas that will smoke everybody (especially if the course is designed by an import guy!). Learning the course and seeing the cones is the hardest part; just go by the saying, "Slow is smooth and smooth is fast." Oh, and have fun!
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Car: too many
Engine: SBC
Transmission: AUTOs and a 5 speed :D
Axle/Gears: you name it
From going to the autocross in Cumberland I was told
first mod=> tighten the loose nut behind the wheel with practice
-no one will do great the first few times
-learn to look ahead and see the course
second mod after you have a couple of events in =>tires!!! (run on street tread first)
(I'm still on first mod myself)
stx or stu with street tires are a good class to start in
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Car: 87 GTA
Car: 88 Trans Am
Engine: 305 tpi
As the others said that since would be your first time out, just make sure your car will pass tech and have a good time. After you get addicted to it (which you probably will) then start looking at the rulebook and see which class you want to go in.
for example, in FS the only things you can do are DOT legal tires(like A6, v710,etc.) , Shocks, front(not rear) swaybar, and air filter(Stock fitting replacement).
The next classes your car would go in this order.
Street Touring Extreme (STX): Allows more suspension changes, cold air intake, full exhaust(must retain all emissions),sub frame connectors(bolt-on ONLY, and 3 attachment points max per side), bushings(non metal), must be on 140+ tread wear tires, and various other things, but it would clutter the page up.
then E Street Prepared: everything from STX, update/backdate(put all the good parts from the same generation car like having a 350tpi, with a 5-speed etc.), DOT R-comps, weld in sub frame connectors allowed(3 attachment points max per side, and not attached to floor pans), and again many more things that would clutter the page.
then it would go to Street Modified(SM) > C Prepared (CP) > Some crazy mod class (probably EM)
There are alot of small things that can put you in a class where you typically won't stand a chance in.
like if you did nothing but take the rear seats out, it would put you directly to SM.
So I would strongly suggest reading the rulebook which can be viewed Here.
And if it doesn't specifically say you can, then you can't.
Addicted?
Wow, I went Saturday to a beginner Autocross class (drive the course with no instruction, then spend all day working / learning / driving and at the end of the day, drive the course again with what you've learned... it was a blast... Though I didn't take my Firebird, (still working on it), I look forward to the day I can.... I know there are many different groups in the area & not sure what you've done to your car, or if upgrading will dictate what class your are in, but I guess my point is, have fun... I had a blast... I have a 91 firebird, TPI, 5 Speed with basic mods.... which is fun for me... Am I gonna be competitive with the guy with the $80k Lotus Elise that weighs 2500lbs with 300 hp? Nope... but I had fun trying & improving on my personal times...
Rafael
Rafael
Car: 85 Z28 scca C Prepared
Engine: 5.7 348 RWHP
Transmission: t5
Axle/Gears: dana 44 3.41
My opinion 3rd gens are the best handling Camaros ever built...By far
Car: 1991 Trans Am GTA
Engine: 1987 350 TPI with mods
Transmission: 700R4 (shift kit)
Ran first SoloII yesterday. 84,Z28 HO 5sp. What a blast!! I'll be looking for tires and shocks. First run 103 min, last 85. Never got out of first! Want to stay in F Stock. SCCA rules are tough.
Car: 1991 Firebird
Axle/Gears: 3.42 w/auburn racers diff
Ask Mark Madarash, hes Taken ESP SCCA solo National Champion In his Trans Am Numerous Times. Sam Strano took a lot of National SCCA AutoX trophies in thirdgens as well. i attached a pic of Marks car....its Sick, anyone know if he is on here?
I have a video on facebook of me taking my 89 firebird. I think it all depends on how they make the track. When i went it wasnst at the speedway here it was in the parking lot of a local casino. The track was extremely small with really tight corners. I didnt do to hot. The announcer was cracking jokes the entire time asking me where my ****** was. he said it was the first time he had ever seen a 3rd gen firebird at autox
