Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Removing rubber marks
Old Aug 21, 2011 | 08:43 AM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
Ok so you go to the drag strip or the road course....end up with black streaks of rubber up the sides of the car or on the nose...well i've tried various methods of removing it before....just ended up scratching the paint....well i love starter fluid, use it for cleaning all kinds of things.... i found it also dissolves rubber stains very quickly....the fresher they are, the faster it works......i spray it on and then rub it with a clean cloth ( i use an old sock)......works great, no harm to the paint......don't smoke while you are doing this..........
Old Aug 21, 2011 | 09:27 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Removing rubber marks
does bug and tar remover work?
wipe the car down with armor-all before the track session, make clean up easier
Old Aug 21, 2011 | 11:05 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Wd40 works well. A little Pam cooking spray on the quarters before hitting the dragstrip works too. However my cars wear their burnout rubber like a badge of honor
Old Aug 21, 2011 | 12:38 PM
hotrodln's Avatar
Engine: Lt1 in IROC
i don't remember trying bug and tar remover....it probably works....but the starter fluid leaves no residue behind.......and it's Fast!
Old Aug 21, 2011 | 07:33 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
x2!
Old Aug 21, 2011 | 07:46 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Mineral spirits in a can from any hard ware store works great! Won't hurt the paint.
Old Aug 22, 2011 | 08:50 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Wax and grease remover from the body shop supply store. I use a gallon a year to remove rubber from all over my car.
Old Aug 23, 2011 | 01:30 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
As mentioned, i dont worry about it like a couple others, but for those with nice pain jobs, WD40 has been a big use for them.
Originally Posted by mw66nova
x2!
I swear Matt, your third gen is the only one i can say i like without the GFX man. You pull it off.
Old Aug 23, 2011 | 01:34 PM
hotrodln's Avatar
Engine: Lt1 in IROC
yeah i spent too much time restoring this car to leave it with random black streaks on the front air dam, across the hood and up the sides of the car.........just makes it look " unkept"
Old Aug 23, 2011 | 04:24 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
You guys will probably think I`m crazy but the best thing I have found is STARTING FLUID, it` works the best with only a very small amount of smearing and has not hurt the paint ever. I do it about twice a year so you can imagine how much I get on there LOL!
Old Aug 23, 2011 | 04:36 PM
hotrodln's Avatar
Engine: Lt1 in IROC
funny, but i've heard that before!
Old Aug 23, 2011 | 07:13 PM
mw66nova's Avatar
Engine: 7.0L
starting fluid? as in?:
Old Aug 23, 2011 | 08:35 PM
hotrodln's Avatar
Engine: Lt1 in IROC
that's the stuff man! works great- i go through a ton of it in my own hobby shop. it's a great degreaser....leaves no trace behind. ever buy a new water pump, brake rotor or any car part that comes with a coat of oil on it, instead of paint? use starter fluid to dissolve the oil and watch it run off....then when it dries....like in 1 minute, you can paint it and the surface is chemically clean.....also works great to clean out varnish from old valve covers, oil pans.....all kinds of things....give it a try, you'll wonder what you did without it!
Old Aug 23, 2011 | 08:47 PM
mw66nova's Avatar
Engine: 7.0L
hmmm...i work at a parts store. i've never heard this use before. i'll be trying it soon. always used brake parts cleaner
Old Aug 23, 2011 | 10:16 PM
hotrodln's Avatar
Engine: Lt1 in IROC
i think brake parts cleaner leaves a residue. Starter fluid is either, which completely evaporates at room temps.....
Old Aug 24, 2011 | 02:51 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Highly flammable as well, LOL.
Old Aug 24, 2011 | 07:25 AM
hotrodln's Avatar
Engine: Lt1 in IROC
don't smoke while using it!
Old Aug 24, 2011 | 04:40 PM
Yea, you`ll like it works well, be careful of the fumes, knock you down if you get hit right....doesn't brake cleaner eat the paint??
Old Aug 24, 2011 | 07:32 PM
mw66nova's Avatar
Engine: 7.0L
well i don't use brake parts cleaner on painted surfaces, i was thinking about like brake rotors, etc.
Old Aug 24, 2011 | 11:16 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Go to an RV store and purchase 'Black Streak Remover'. It's safe for paint and removes rubber scuffs.
http://www.thetford.com/Home/Product...9/Default.aspx
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
3rdgenparts
Aug 8, 2015 07:09 PM
