Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Got the car to the track for a base time.
Old Aug 28, 2011 | 09:41 PM
383 rs's Avatar
Ok i finally got the car to the track. I got the paint buffed out this week. Which i am pretty happy with for my first paint job. But i got the car to go 11.79 at 113mph. 1.72 60 ft. The car has a 342 gear in it. How much time do you think it could pick up swapping to a 410?
Old Aug 28, 2011 | 09:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Got the car to the track for a base time.
Depends what rpm you shift at.
Depends what rpm you cross the finish line at.
Depends what gear you cross the finish line at.
If geared properly for the engine rpm range, you should be crossing the finish line at or just after you reach your shift point in 1:1 gear. OD isn't a recommended gear for dragstrip use. You should be maxed out in gears and rpms as you cross the finish line.
So many factors can change that including a stall speed change in the torque converter.
Old Aug 28, 2011 | 09:52 PM
383 rs's Avatar
well I dont have a playback on the tach. But I have the light set at 5900 and i would say its actually shifting at 6000. It was crossing through the traps at around 5k or a little under. And im running a th350 so of course im in third gear.
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Kaweh
Aug 9, 2015 02:54 PM
Fronzizzle
Aug 9, 2015 01:15 PM
