Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
How to run 1/4 with 150 shot, slicks, and auto trans?
Old Oct 10, 2000 | 07:54 AM
Superblue87Formula's Avatar
I am thinking of adding 150 shot and 26x9 slicks to my car for next season. I have no idea how to run w/ nos and slicks!
-how much pressure should I put in the slicks, how long should I burn out??
-how do I launch (stall it or just mash the gas)
-when do I arm/activate the NOS?
Thx in advance -josh
1987 Formula 350, headman hedders, Accel supercoil, cap, rotor.
MAF screens removed. 160 degree stat and manual fan switch.
Best ET: 14.745@91.317mph-Stock
Best ET: 14.418@95.51 mph-Modded
Ridiculed Founder of the Traction Impaired Crew
Old Oct 10, 2000 | 07:35 PM
TINFY Racing's Avatar
well all i know is you better hold on tight and enjoy the ride.TINFY
Old Oct 12, 2000 | 01:48 PM
rich1034's Avatar
I would start with the smallest jets, and work on traction first. Start at 20psi in your slicks, and work from there. Your launch shouldn't be affected too much, because unless you launch at wide open, your nitrous isn't going to be engaged yet anyway, if you do launch at WFO, just go with the smallest jets first, and then move up as you figure out traction
Old Oct 12, 2000 | 05:03 PM
20-psi's Avatar
Do you have any suspension mods? If you don't, hitting the button will just cause you to spin your tires.
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
