More ooooomph for $500...
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Hey guys. For Christmas I was thinking of the following solutions to improve times next summer. My best of 13.8 is really the tip of what I want to acheive. The ZZ4 is running real strong though traction and hooking up is and always will be a prob with the 2.7 open rear... Here are my favourite options any advice is welcome
1) LT-4 HOT cam, runs the ZZ4 up to around 387 BHP
2) SSM traction kit, includes lift bars, sfc's, driveshaft hoop and crossmember
3) 125 bhp Nitrous kit (actually the cheapest option)
4) Rear gear - maybe 3.42's with POSI (getting hold of this in the Uk is not easy though!!)
So what do ya reckon?
'86 Iroc ZZ4
Best Run 13.8 @ 100mph
I told you to blow the bloody doors off!
The British Firebird/Camaro Site
'86 Iroc ZZ4
I'd go with some LCA($90), posi($310), and some 3.42 gears ($150).
If you have a ZZ4 these should be mandatory, I repeat mandatory.
I guess it might cost you more overseas.
Also, some LCA lowering brackets ($65)wouldn't hurt.
FELIX,,
How the heck are you??????????
I ve been wondering if you were still on the board??
WOW, I guess, I should bring you up to date as a friend here locally has a ZZ4 motor now, but he went with the TPI setup, maybe you could give him some advice. his sign on is KREAM..
Check out the new time..
1986 Grand National
Big fuel pump w/ hot wire kit
30lb injectors
Custom Street Chip
Underdrive Pulley, 160 therm, K&N,Mass air pipe
Adj Fuel Reg.
2800 Stall convertor
3" single exhaust
Air Bags
13.30@103.2 on the radials(2.004 60 ft) and 17#'s of boost
1986 Grand National
30lb injectors
Custom Street Chip
Adj Fuel Reg.
3" single exhaust
Air Bags
Car: 1988 IROC Vert
Engine: 355 ZZ4
Hey Phil how you doin??
Like the time, looks like you're up with Ian's times again
So whats been happening? I've got married and honeymoon'd recently so I have had many things on mind
It's all gone damn well, 120 at the wedding and Mauritious for the Honeymoon...
So what car is the ZZ4 in? He will have to mod his TPi set up big time to let that motor run strong... give me the details!!
Good to hear from ya!
It's all gone damn well, 120 at the wedding and Mauritious for the Honeymoon...So what car is the ZZ4 in? He will have to mod his TPi set up big time to let that motor run strong... give me the details!!
Im doing well, I figure that next time out I can hit the 12's on the radials, I recently purchased some Nitto Drag radials, I will also be replacing my worn out valve springs(No head work just replacing) and Im going to a slightly upgrade turbo, I want to run in the 12's on the current setup, then timeit with the new mods.
CONGRAT's on the marriage.
As far as upgrades for your car I would stick with all the plans BUT the cam, no sense making more power when you cant put what you got down on the pavement. I would do the cam as the last thing.
The car witht he zz4 motor is a 88 I think, we had the car on the diacom and everything look good, but timing is having to be kept around 0 so it wont knock(ping), I think there alot more in the car, on the Gtech computer it has run LOW 14's...here is a link http://content.communities.msn.com/i...ess&ID_Topic=4
Later
Phil
1986 Grand National
30lb injectors
Custom Street Chip
Adj Fuel Reg.
3" single exhaust
Air Bags
Later
Phil
1986 Grand National
30lb injectors
Custom Street Chip
Adj Fuel Reg.
3" single exhaust
Air Bags
Car: 1988 IROC Vert
Engine: 355 ZZ4
Phil,
Sounds like your car is running strong, keep me updated! How much is the turbo upgrade going to cost?
I guess the suspension mod is (ssm kit) is the first mod, like you say power is nothing without control
If I was being REALLY sensible I would do domething about the brakes but that is if
KREAM's car looks good, I had the same problem with pinging in mine and I run with 0 timing too... Is there much performance in advancing it?
Can't believe the Summer is over
Another year and then back for the Euronationals against Ian again, I'll be quicker but I can put money on the fact that he will be too... Gotta love the drag scene.
Laters
'86 Iroc ZZ4
http://www.geocities.com/ukzz4iroc/]The British Firebird/Camaro Site[/URL]
Another year and then back for the Euronationals against Ian again, I'll be quicker but I can put money on the fact that he will be too... Gotta love the drag scene.Laters
'86 Iroc ZZ4
oddscrounger
Nov 2, 2012 12:07 PM
