2.8 chevy camaro help
Old Feb 10, 2012 | 10:08 AM
88cam23's Avatar
I picked up a 88 chevy camaro last year for 500... I bought it from my cousin and he told me it was running fine and he drove it home shut it off and the next day it never started. After that it set for a few years before I bought it from him.
I figured it was some thing simple and found the fuel pump wasn't working so I replaced that and got the car to start. Right away the car would rev up very high then it would rev down low then rev back up. I replaced the Mass air and the TPS. I never could get the TPS adjusted correctly no matter what I did. I am starting to think it could be the ECM? also the gauges all seem whack(oil,rpm gauge) If any one has any ideas to help me get this thing driving again please let me know.
The car has only 80,000 miles.
Old Feb 10, 2012 | 05:54 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: 2.8 chevy camaro help
What do you mean, you couldn't get the TPS adjusted correctly? You set it up, and then the voltages don't return to the correct values? That'd mean it's broken, but a bad TPS won't cause the engine to rev way up like you described, just hunt around a bit. Try disconnecting the idle air control and see if the idle remains constant... if so, that's likely the problem.
Old Feb 10, 2012 | 07:02 PM
88cam23's Avatar
I mean I cant get it set to the correct value at all. Ive tried 2 TPS. Ill check into the IAC tomorrow and see what happens. Another thing that is leading me to ECM is when I turn the key to start.... the engine light doesnt come on at all. I figured it would come on for a few seconds and turn off.
Old Feb 14, 2012 | 09:35 AM
88cam23's Avatar
Ok I am needing a little help... I noticed when turning the car over my gauges go up. For example the MPH OIL gauge both go up as I am turning the car over. I get no indicator lights at all when I turn the key the check engine light doesnt even come on at all . So I pulled the computer disconnected it and tried cranking the gauges still bug out when turning the car over.
Any ideas? I did notice the computer is a re-manufactured one.
Old Feb 14, 2012 | 10:36 PM
88cam23's Avatar
ok with a new tps the car is starting and idling sounds a little high tho. Now the problem I am having is if I even slight touch the pedal it bogs down and cuts out but picks back up as soon as I let off.
If I push the pedal super slow I can get it a 1/4 of the way down but the car chokes and sputters.
Ill test the fuel pressure tomorrow and see what that says.
Old Feb 15, 2012 | 11:57 AM
88cam23's Avatar
To much going on in this post lets lock or delete this.
jhawkeye
May 25, 2022 06:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
BADNBLK
Nov 16, 2016 09:12 AM
Reborn756
Sep 4, 2015 03:42 AM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
