engine pinging
Old Feb 15, 2012 | 03:41 AM
lopezstud87's Avatar
Car: 2010 2SS/RS L99-1987 Iroc-z
Engine: 383sbc/Built 350TPI
Transmission: Built T56/700R4
engine pinging
I got a 87 Iroc 350tpi and the engine pings when driving normal.I have set the timing to everything to see if it would stop wit the est unplugged wit no luck.any one know anything I can check to see if something isn't right or wrong.
New
Maf
Spark plugs and wires
Tps
Idle air valve
Coil
Control module(h.e.I)
Old Feb 15, 2012 | 05:13 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: engine pinging
Checked oil level?
Old Feb 15, 2012 | 06:34 AM
Re: engine pinging
Originally Posted by t-top havoc
Checked oil level?
I changed the oil couple of months ago so shouldn't be low..
Old Feb 15, 2012 | 06:45 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: engine pinging
Assume this is pre-ignition. Not detonation at WOT?
EGR. EGR provides exhaust gas into the combustion chamber in order to cool combustion temps and reduce pinging at low throttle tip in. This allows the ECM to command more timing advance with a leaner mixture at low throttle cruise for better mileage.
Pinging is also more prevalent at higher engine temps and can be exacerbated by bad, or the wrong kind of, plugs.
Old Feb 15, 2012 | 02:23 PM
Re: engine pinging
I really dont know what its called,just know that its not like a rod knocking..just know that i can feel it while im in the car and really feel it shakin bad when i give it some gas..its been doiing this for weeks now but at first wasnt bad,would only act up i guess after the car warmed up maybe but now all the time...could be egr as well..thats one thing i havent changed in it
Old Feb 15, 2012 | 02:27 PM
naf's Avatar
naf
Re: engine pinging
Pinging won't cause 'bad' shaking. Sounds like a mis-fire. Check all of you ignition components, check your injectors, check for trouble codes.
It could still be a sticking EGR valve, but another cause is more likely. You can check your EGR by disconnecting it to see if this affects it.
Old Feb 15, 2012 | 02:44 PM
Re: engine pinging
no codes...this car doesnt like to throw codes for some reason...alright ill check all that...thanks for the help...what should the fuel pressure be again
Old Feb 15, 2012 | 03:04 PM
naf's Avatar
naf
Re: engine pinging
I'd repost this as a mis-fire/shakin real bad issue in the TPI tech board.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
