60' times
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
60' times
went drag racing today and never had a60' time below 2.1 mainly 2.2. my best time was 13.1 at 110 mph- i think if iget my 60' time down i'll be in the 12s. i've got lakewood lcr and bfg drag radials any ideas how to help?
86 camaro 405 sm. blk. th 350 tranny 3.42 gears
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
get some tires now
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
13.24@104
coupe questions?
What tire pressure are you running?
What is your Pinion angle set at?
Are you running drag shocks in the rear?
Have you removed the front sway bar, or just loosen it up for track duty(better weight transfer).
HTH
1986 Grand National
Big fuel pump w/ hot wire kit
30lb injectors
Custom Street Chip
Underdrive Pulley, 160 therm, K&N,Mass air pipe
Adj Fuel Reg.
2800 Stall convertor
3" single exhaust
Air Bags
13.30@103.2 on the radials(2.004 60 ft) and 17#'s of boost
Car: 86 camaro
i was running 20 # in my rears no front sway bar, pinion angle at stock with ab&m kit.spoun's arm may be the answer it's just so expensive
