Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
2 tenths in 60 nets 1 tenth in 1/4 ?
Old Oct 23, 2000 | 07:54 AM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Put the new BFG DR's on, 225-50 15 with small
diameter so as not to ruin my gear ratio. They hooked good cutting my 60 from 2.27 (14.52 @ 96.24) to 2.0x for three runs;
14.44 @ 93.5, 14.63 @ 92.77, and 14.76 @ 94.06. I thought better short times were
supposed to result in much better 1/4's ?
Car was not changed at all from the 14.52 run in Aug to these runs. I must have put a
whole 80-90 miles on the car between the two times at the track so car variables are
small and the car did run good. Only thing
I can think of is the drag difference in the rear tires with the street tires run at 35
psi and the DR's at 23. Also my friends LS1
2000 Corvette ran for the first time and had
3 runs with 100.xx mph for top speed which seems rather low. Maybe weather conditions
(pressure and humidity). This Sat was unseasonably warm in the northeast.
Tom K.
84 z-28 M5 305 HO
pulleys,coil,3:73(stock)
Jet StageII, fan switch
14.55 @ 95.02 2.15 60ft
Old Oct 26, 2000 | 07:51 AM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Wow, nobody wants to take a shot at this question ?
Tom K.
84 z-28 M5 305 HO
[This message has been edited by 84305HO (edited October 26, 2000).]
Old Nov 3, 2000 | 07:27 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
I guess I'll anwser my own question. Is was the weather! Went the next weekend with no changes and went 14.20 @ 96.74, 2.02 60 ft, and it was about 45 degrees. Time to change the signature....
Tom K.
84 z-28 M5 305 HO
[This message has been edited by 84305HO (edited November 03, 2000).]
Old Nov 16, 2000 | 07:36 AM
Mark W. Winning's Avatar
Normally, the rule is a tenth picked up on the 60' is worth 2 tenths on the long end. I has held pretty close to true for me.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Nov 30, 2000 | 09:31 AM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
Genereally the one at the bottom equals two at the top addage is true if the car has no problem with top end power.
Sometimes it takes a while to get it to hook and not bog.
It's always SOMETHING
"Sounds like Barry White at idle, Teddy Pendegrass wide open..
if it don't sound like Micheal Bolton your alright"
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
tricky1
Aug 23, 2015 01:17 PM
