desperatly need traction!!
Can some body help me!!! I need to get traction with a 92 RS . stock rear-end . The car will spin through third off the line !THANKS FOR THE ADVICE
here are the mods-14x3 Open element w/ K&N filter, MSD 6a, MSD GM blaster Coil ,MSD 8.5 SC wires, AFPR,Fuel Pressure gauge(60Psi max), 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
Crew Chief Underdog Racing 92 camaro rs 15.2 et @89.02
Im taking a blind shot at this but maybe for the time being put something heavy in the hatch/trunk?????
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Kills:
95 (****) Probe GT
94 Mustang GT
91 CRX (dont ask me why he raced me)
2nd Gen Z28 (350) haha to you V8 guys!
1992 RS 305 TBI (good race)
More to come
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
TB Coolant bypass
Kills:
95 (****) Probe GT
94 Mustang GT
More to come
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Try getting as posi.
Justin 87 GTA--organizer: "NY2K" Gathering. Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 *This car is 100% NYS emissions legal, w/ all emissions controls!* "If you want to have a fast car, hang out w/ those who do!"
http:// www.community.webtv.net/munks87/JustinsGTApage.com
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
disconnect sway bar.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
13.24@104
All of the above helps, but I stuck my Z28 in the low 13's/1.96 60' w/ 3.42's in an open rearend (one tire pulling)with a pair of (well one, really) M/T ET Streets. Now I have 4.10's, 4000 convertor and a spool, and I recently beat a friend's stang on the street that runs 12.50's, so I can't wait to put it on the clock. Sticky tires are the way to go.JMHO
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
http://www.bassettracing.cz28.com
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Numbah-1
Sep 12, 2015 08:57 PM
Amrish
Nov 9, 2001 11:33 AM
