All my mods are listed in my signature.I'd like to just get a basic opinion on how much power my engine might be putting out before i do anything else to it.If anyone out there has a desk top dyno on their computer,would you please put in my mods and tell me what the desk top dyno says (hopeing to get one soon)?Thanks.
82 firebird with 305H.O.,Block bored .30 over,Keith black hyperutectic flat top pistons for 10 to 1 compression,Turned crank,Magnafluxed connecting rods,Melling H.V. oil pump,and double roller timeing chain,Ported and shaved heads w/3angle valve job,Z-28springs,Summit push rods and comp cams magnum roller rockers,Ported Edelbrock performer r.p.m.intake,Carter 625 afbcarb,Accell spark plugs,wires,and H.E.I.super coil,Heavy duty cap and rotor,Clevite performance cam with 450-460 inches of lift,Comp cams lifters,700r-4 tranny rebuilt with trans-go rebuild kit,corvette servo,New torQue converter,Flowtech headers,Flowmaster muffler,3.73limited slip rear end,Energy suspension bushings from front to rear,Energy suspension tranny mount,New center link,ball joints,trans-am steering box,ASP power pully.
Well, I plugged in your parts in Desktop Dyno 2000, and it says you have: 429 HP @ 6500 and 394 Ft. Lbs @4500
Does this sound right to everyone else? I wasnt expecting that high of numbers. My motor is alot like yours, only bored 10 over, but pretty similiar! hehe, I love 305s!!
-Roshambo
-Roshambo
Sounds too high to me. When you consider most of the stuff in the sig has nothing to do with engine performance. Since a 305 and there isn't enough cam specs, I'd guess it's closer to 290-340hp
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
Here are my cam specs-Advertised duration-292int,288exh.-Duration at 50-224int,224exh.-Valve lift-450int,460exh.
