Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Quarter Mile
Old Jan 1, 2001 | 12:12 PM
AustinT's Avatar
Quarter Mile
I have a zz430 for my 89 Camaro with a WC T5 and 3.08 rear gears. What kind of times and Mph do you think Ill be able to get out of it. What could I do to improve these times.
Old Jan 1, 2001 | 05:50 PM
NJ SPEEDER's Avatar
what kind of suspension do you have? an average weight f-body(about 3400lbs) with that sort of power could probly be capable of high 12's if it is hooked up at about 107-108mph.
lata
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
The car is going street strip for next season. 13's here i come!!!!!
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall),Steve Spohn Rear Rig( all rod ends), Poly Front Bushings,Ported TB, 350 Injectors, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
http://www.mycar.net/mafb/registry/detail.cfm?id=299
Old Jan 1, 2001 | 08:09 PM
AustinT's Avatar
I have A bone stock suspension for now. What would you reccomend? Ill be running 245/16 tires
Old Jan 1, 2001 | 09:35 PM
NJ SPEEDER's Avatar
i would recomend getting th esteve spohn stuff for the rear, as well as either some sort of drag launch springs or v6 springs all around. i would also suggest some 50/50 shocks for the back and 90/10 struts up front. the shocks are like $40 each and the struts are closer to $100. also never overlook the tires, i run hoosier quick time pro's, they are DOT legal and hook like a **** with ajust a little bit of heat in them.
if i had to start somewhere i would do the tires first.
lata
tim
14.301 @ 94.39mph
83 Crossfire TA
Jan 3, 2016 01:26 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Exxon Limited
Aug 9, 2015 08:13 PM
