Manually shifting a 700R4 auto???......
I do it sometimes if I race,is it safe for the trans???If so,is it safe to shift at the red line in 1st and 2nd gear???
86 iroc,canary yellow,fully loaded
Car: '94 Corvette
It's fine to manualy shift your trans. As far as redline goes, it all depends on how high we are talking about. Just like any rotating mass it wants to pull itself apart at super high RPM's, but I wouldn't concern myself with that unless I was pushing 7000+ RPM's with a stock 700.
You also need to get your car dyno'ed, and this will tell you the best RPM to shift. The painted red line on the tach, doesn't mean squat !!! The red line shouldn't not be used as a line where peak HP is produced, unless your lucky enough that it works out that way.
If it makes you feel better, I have full manual TH350, so I have to manualy shift every gear all the time. My biggest concern shifting at 6500 RPM's is the U-Joints !!!
Good Luck,
Ron C. Terry
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Good Luck,
Ron C. Terry
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
I have manually shifted my 700R-4 tranny for over 7 years ever since I bought my car. I shift it up and down every time i drive the car. I canyon carve and shift up and down continuously. Anyone who says it is bad for the tranny is smoking crack.
FORMULA 350 TK
Southern California 3rd Generation F-Body Organization©
FORMULA 350 TK
When downshifting, just make sure you blip the throttle a little bit before pulling the shifter back. It raises the line pressure and gives a cleaner shift. The tranny doesn't really like it if you just pull back on the stick while idling along at 30mph with your foor off the gas.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
91 Trans Am WS6
Bright White
5.0 TPI auto
Trans Go shiftkit
Built on Wednesday
C409
Sep 1, 2015 03:42 PM
someone972
Aug 30, 2015 12:52 AM
dhonda200
Aug 11, 2015 11:50 PM
