Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
which sway bar is better....
Old Jan 29, 2001 | 11:27 PM
james_fearn's Avatar
I have my stock 32 mm solid s/b and a hollow 34 mm s/b that I got of a later camaro that came with a wonder bar. Are they equivalent (exept for weight) in performance?
James
1985 Z-28 305 TPI
220,000 mi., Original Eng.
Old Jan 30, 2001 | 04:24 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I'm not totally sure, but I thought that only the 36mm sway bar was the hollow one. But the 36mm is equal to the 34mm in strength and stabilty. The difference is that the 36mm weighs less. So if your measurements are right, then the 34mm will be a better choice. No matter what, use the wonder bar.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
