Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
(weight transfer) best bang for the buck? What makes a 3rd gen hook!
Old Jan 12, 2001 | 09:52 AM
Z-BOSS's Avatar
I'm a broke 21 year old college student that has built an 86 Iroc with a 383 tpi with gobbs of torque.
What is the best bang for the buck when it comes to traction? I already know tires will, but I want my car to hook off the suspension.
I don't care about handling and cornering I want launching!!!!!, I'm talking about good 60 foot times. I know there is a lot of free mods when it comes to horsepower but what about suspension.
also what are lca's.
I've taken off the front sway bar , got a glass hood, relocated the battery, hulled out the bumpers, got an aluminum radiator, took off the smog and air.
What about v6 springs do they work?, what are a good pair of front shocks(for a decent price) even though wore out ones transferr pretty well.
I really don't want to put skinnys on the front.
what good is horsepower if ya don't hook! I want to leave stangs at the line!
what have you done to make a car hook and how well did it work.
I think I'm the only street racer in MS that drives a 3rd gen camaro and that leaves very little help for me. I'm beginning to link my car is a dying breed!
I'll appreciate any advice.
Old Jan 12, 2001 | 11:59 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Ummm.... you have shocks up front?
I use v-6 springs front and back, worn out struts up front and a little stiffer shock in back and a set of slicks. Of course no swaybar, battery in back, etc....
For the street, run ET Streets.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Old Jan 12, 2001 | 12:26 PM
Z-BOSS's Avatar
[QUOTE]Originally posted by 88 427 Camaro:
[B]Ummm.... you have shocks up front?
Miles
Well I have struts up front(wore out ones), but I think being wore out may help the front end rise.
I would like to run drag radials to keep a sleeper effect. With my 4" coul everyone thinks I got a big block. But.... The 383tpi with the 262xm comp cam & 1.6 roller rockers is quieter than a sewing machine so they so they don't know what they are getting into.
3rd gen camaros with tpi are rare at home and I haven't yet found one to run faster than 8.90 in an 1/8.
That alone makes me a sleeper no matter what my appearance. That sad!!!
But I be da@# if I don't use to my advantage
Old Jan 12, 2001 | 04:02 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
I believe that v6 and v8 rear springs are the same. Only the v6 spring rate is less in the front.
87 Z28 305 TPI, Auto, 2.73, Gutted air boxes, K & N fillters, SLP Airfoil, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 170* Stat.
Best 15.414 @ 87.47.
Old Jan 12, 2001 | 07:10 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Worn out struts usually help because they are softer. The better route is drag struts that have adjustable extension (soft) and compression (hard) settings.
The drag radials will help with the sleeper look, but the ET streets will have a lot better traction.
Miles
88 427 Camaro
www.koolmeister.com
Old Jan 12, 2001 | 08:33 PM
NJ SPEEDER's Avatar
TIRES!!!!!!!!!!
only one part of a car can actually grip the road, the TIRES!!!!!
i would suggest looking for some cheap rims at a swap meet or off the classifieds and find some tires. tires aren't a really terrible expense, if ya just use them for racing they can last you a couple years. i run hoosier quick time pro's, they lasted all the way through last season and they have enough tread to make it through at least one more.
also 50/50 shocks for the back are cheap. rear control arm relocators and if any of your friends knows how to weld, box the the stock control arms and torque arm. also switch both to poly bushings.
and now my favorite topic, WEIGHT CONTROL
try to axe weight from the front of the car, the less that is up front the better the weight distribution, and better transfer. moving the battery to the back would can be done with a relocation kit and a safety switch for about $70. that takes about 40lbs off the front and puts it on the back.
hope some of this helps
lata
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
The car is going street strip for next season. 13's here i come!!!!!
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall),Steve Spohn Rear Rig( all rod ends), Poly Front Bushings,Ported TB, 350 Injectors, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
http://www.mycar.net/mafb/registry/detail.cfm?id=299
Old Jan 28, 2001 | 10:11 AM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
LCA are Lower Control Arms.
There is one on each side of your rear axle, helps hold it in place. The stock LCA's are ok. With your 383 you could probably gain something from modding or replacing them.
SLP had stock LCA's with a 1/4 plate welded to them to stiffen them up so they don't deflect. The SLP part has harder urthane bushings.
You could get your old LCA's reinforced and order some bushings. When I looked at doing this for my 99 T/A LS1, (same rear suspension) it was going to be $65 for the bushings and $30 to get the LCA's welded up. SLP had the same thing for $110 or a tad more so it was worth it to just order new LCA's.
Also the Panhard rod, it runs side to side in the rear suspension could be replaced with a reinforced one with harder bushings. SLP also has these they cost about $60.
Lakewood and others have LCA's so you might want to check around.
The LCA's and Panhard are worth doing.
Old Jan 29, 2001 | 01:43 AM
Basett Racing's Avatar
A good tubular torque arm that is mounted to the floor instead of the tranny makes a tremendous difference also. Even a stock one with some 3/4 DOM tubing welded in the rounded indentions and a polyurethane torque arm bushing works well - I used that set-up for a long before fabbing a nicer, floor mounted, tubular one. But I have to agree with NJ SPEEDER, if I had to choose only one, it would surely be TIRES.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
Old Jan 29, 2001 | 09:48 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
youd be suprised what a difference just putting the drag radials on did....you can get about 3000miles out of them on the street and with a quick burnout and 18psi they hook great!
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 226/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
13.24@104
Old Jan 29, 2001 | 11:38 PM
BadSS's Avatar
Z-BOSS finally another MS dude. They're hardly any TPI cars running around here anymore. There's not even many 3rd gens going to the track either - which one you go to,, or what part of the state do you race? I ditto the tires.
Old Jan 30, 2001 | 07:57 AM
Z-BOSS's Avatar
Hardly any tpi cars........hell there's hardly any 3rd gens in north MS! And there isn't any that race. I live in Ripley so locally I'll be running and tuning in Blue Mountain. I'm going to try fulton and Holly Springs. When the NMCA starts up the efi classes I'll try to run some of the closer events(MEMPHIS,Bowlengreen,and the one in Alabama. Yeah...all there is to race mustangs and 4th gen TA's and camaro's.
Where are you from and were do you race.
I just pulled my motor a week ago I got a little modifing to do I'll have her going soon though.
Getty up my *** this ain't no damn pony ride!!!!
86 IROC 383tpi
The "bone stock" that rocks!
Old Jan 30, 2001 | 03:29 PM
BadSS's Avatar
I’m from Jackson (Central MS for the out of state readers). Well,, there is a so called track in Canton (about 20 miles north),, but the only thing I’d run down it is a lawn mower. The closest “real” tracks are Lena (about 90 miles east – for Saturday racing) and Hattiesburg (about 90 miles south – for Sunday racing). I have gone to Baton Rouge,, just for a change of scenery, but not often. I could see myself making a trip to Memphis sometime. This is my first modified EFI car, so I may look into the NMCA EFI rules,, but I hate bracket racing.
There are a few TPI cars still in daily use around here. One kid at Gateway tire supposedly has a ZZ3(I think) with the TPI on it,, but I’ve yet to see it run and there’s a guy at Big 10 Tires that has a loud one that smokes, again supposed to be fast,, but I’ve yet to see it run either. One friend has a bone stock 1991 305 TPI that is really nice (high miles though). The next door neighbor, former President of the Central MS Camaro Club has a super fine well taken care of 84 HO that still looks new (for sale).
If I go to Memphis this year,, I'll try to contact you.
86 IROC - 9.8:1 - 355, TFS twisted wedge heads, 218/228-110, fully ported GM base and plenum, SLP runners, 52mm BBK, 24# SVO, 88 350 GM EPROM, 1 5/8" Headman headers, 2.5" Dynomax, TH350, 2200 stall, B&M Megashifter, 3.23 peg leg, 245/45ZR17 on 212 Eagles
Old Jan 30, 2001 | 07:28 PM
Z-BOSS's Avatar
Is that time on all motor....if it is it's damn good. Hell if it was on gas it's still not bad. I mainly only run the 1/8 mile because that's all the tracks are around here and that's about all the we street race. I'd like to run the 12 sec efi class at Memphis with a 50-75 shot, but I may just slow her down a bit and run the 13 second class on motor. What's different about the twisted wedge heads than the regular trickflow's. I just purchased a pair of regular trickflow's fully ported for a rather fair price. I've been delayed with a crack piston. So I'll get her sleeved on two sides but I ought to get her going in a month or so...
Hollar at ya later
86 IROC 383tpi
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
z28addict8490
Aug 7, 2015 08:48 PM
