Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Car can't grip road and goes sideways..need opinions
Old Feb 24, 2001 | 02:41 PM
theformula's Avatar
Check my signature for info on my car. It says I have auburn posi. I do, but it's not installed yet. So my rear is OPEN.
The roads here are dry.
I went through a puddle while exiting Red Lobster . I drove down the road a little then gunned it in 2nd gear. My car started going no where while RPMs were rising. Was this because my tires were a little wet? Do I have to much hp for street tires to be doing this? Is it because of the open rear I have?
What can I do to prevent this?? Any suspension mods?
I really do not want to wreck my car again...
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited February 24, 2001).]
Old Feb 25, 2001 | 08:17 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
It's the open rear! If it is not 100% dry my car does this on the 1-2 shift every time,and I have a 9 bolt posi.
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter. 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old Feb 25, 2001 | 09:40 PM
TINFY Racing's Avatar
yea its because of the rearend and the fact that it was slightly wet. change to a posi and it shouldnt spin as much but it will probrably still spin. on a wet road.TINFY
customblackbird
Aug 15, 2021 10:16 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TEDSgrad
Mid-West Region
Aug 10, 2015 07:12 AM
Exxon Limited
Aug 9, 2015 08:13 PM
