Got my headers on...
Hey guys, just got my headers on this past weekend. They are cheap Flowtech headers, but, listen to this. I have an 88 Iroc with a 350TPI and 700R tranny. The only mod was flowmaster mufflers and a few degrees on my timing. My best pass with that was only
15.03@91mph....yeah pretty bad. Then I put those headers on my car, gutted the air boxes and gutted my cat. I took it to the track and ran
14.63@93 mph. Not bad for only $150 bucks huh?! Anyway, my next mod will be a cam and some lowering springs to help with my traction. I will keep you guys posted!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
ET means nothing. That depends on traction. However you did pick up 2 mph. That's a direct result of HP. Either that or the air conditions were much better. The best way to tell if it was an improvement is over a few weekends. Each weekend the air should be different. If it's always a better run then the changes you did were an improvement.
I've seen people do a bunch of changes and expected to run quicker but actually slowed down. They blame it on the parts they used but it was because they retested on a bad air day.
Still. 2 mph is good for that price.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
redformula88
Oct 14, 2015 06:08 PM
