Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Manual steering or PS for AutoX
Old Mar 3, 2001 | 09:27 PM
Bort62's Avatar
Im Interested in Roadracing/autoX With My Camaro, Not So Much Drag.
My PS Has been out For a while, And Instead of just replacing hte pump I had considerd Going to Manual steering. I really like the stiffer, More absolute feel On the street.
The only Thing is, I dont want to Do something that is going to Make Roadracing Impossible.
What are your Opinions on this ? Any of you Guys using manual steering in the twisties ?
Thanks.
BTW, I would be using an S10 box most likely, unless anyone else has any brilliant Ideas )
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 7, 2001 | 06:58 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
To me I'd go with the PS, too many turns with my car and my arms get tired. Plus the s10 box has more turning range.I think it could be dangerous if in a turn you over turned the wheel and couldn't get it straight quick enough. I didn't help much but I though it might help.
Later
JOhn
82 Firebird,355,Cam 224/234, .466/.488,TH350 Tranny,650 HolleyDP,Hooker Headers(I.E. POS) Manual steering
Best 8th et 8.62@80mph.
NEW for 01
A 408,dart iron eagle heads,street dominator intake, 750 SD,cam 229/239, .497/.520, Also a big hole in the hood.
Shooting for low 12's.
Check out my birds new home. It isn't much to look at but give me a couple years.
Http://www.geocities.com/spuds82firebird
Old Mar 7, 2001 | 12:36 PM
Bort62's Avatar
Thanks Spud, what I was looking For. Someone with AutoX experiance.
Ill Stick with the PS I guess.
Old Mar 8, 2001 | 06:28 PM
98_1LE's Avatar
Most definately power steering. Two reasons really, first is that manual boxes almost always have slower ratio steering meaning that you have to turn the steering wheel farther to acheive the same motion at the tire. Second is the work required from the lack of power assist You will go faster with PS.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Mar 26, 2001 | 06:45 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Yes, one more vote for power steering. if you start cranking caster into it, you'll really feel it in the turns. Autocross tracks are normally pretty tight, with an emphasis on tight turns and handling. definitely go power. later on, if you want, you can get a quicker ratio box out of a ws6 firebird or something.
Clem
Old Mar 26, 2001 | 09:25 PM
Redbird's Avatar
Car: '87 Firebird
Engine: '89 Corvette L98, unstock
Axle/Gears: 3.23 posi
Add one more vote for Power Steering....
Redbird
Bayou Motorsports
87 Firebird-Daily Driver/Autocrosser
84 Z28-Full bore Autocross car
Delta Region SCCA
#00 C Prepared
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
