wil bad start kill my time?
I went racing this weekend (street racing) and i lsot to a couple imports and i think it was becasue of my starts. If i got a better sart, i think it would make all the difference. do you agree
Steve
88 Firebird TBI,TH700R4 - Open Element, Cat Delete, K&N filter 14*4 element
1/4: 16.1@85.7
Steve
1/4: 16.1@85.7
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
It depends if you mean reaction time or your launch (as seen in your 60-foot time). If you meant reaction time, that doesn't matter in regular Test-n-Tune. If you meant in how you're launching, that plays a big part in your 1/4-mile time. From what I've seen and experienced for our kind of cars, a tenth of a second reduction in your 60' time give .14-.16 of second reduction in your 1/4-mile time. If you get better traction by using Drag Radials or some sort of stickier tires, you can gain even more if you've been spinning your tires on the 1-2 shift.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
The start can make all the difference.
I ran a 15.24@93.2mph with my 0-60mph time 6.73 seconds.
Later I ran a 17.74@98.2mph with a 0-60mph time of 6.26 seconds. That's my best run ever and I'm well happy as I'm running a 305 with very little done to it. It was a VERY cold day though, so that would have helped a little.
Good luck though
Rob
Good luck though
Rob
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I'm assuming you meant a 14.74 or something there RMK...
But yeah, your start can make alot of difference. At the strip your 60' is all that really matters as far as ET, but if you give the guy you're racing enough of a head start (with reaction time) he will still cross the line before you even if you ran a better time. On the street your reaction time matters alot. Actual ET doesn't matter there, it's who gets to the finish line first. Your launch still comes into effect on the street as well. Obviously if you are spinning too much while the other guy is accelerating you would blow any bit of a reaction jump you may have had, or dig yourself deeper into a hole if they other guy jumped you...
What cars were you racing? Because even w/ the best of starts you are in danger of losing to quite a few imports w/ a 16.1 1/4 mile time...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited March 26, 2001).]
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
I lost to a 96 nissan alima only has an exhaust. i lost to a 97 integra by only one car length, it is heavily motified, then i lost to a 1998 v-6 firebird also heavily motified. the funny thing is that the altima beat me the most, by two car lenghts
Steve
1/4: 16.1@85.7
Steve
1/4: 16.1@85.7
I dont think the V6 bird that beat you was heavily modified. No offense, but your car just isn't that fast. The V6 birds run mid 15s/low 15s.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
91 Formula
305 TPI 5speed
1LE/G92/WS6
I have an 88 IROC and it used to have the same motor that's in your car, a TBI 305. Bone stock with open element air cleaner my best was a 16.11 so you're in the same ballpark as me. The car was very consistent though. After a total of 11 passes, they all ranged from 16.11 to 16.15. It made a killer bracket car but was too slow for me so the first thing I did was pull the motor and build a new one with a tpi.
'88 IROC TPI 355, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp Roller Rockers, Comp Cams TPI cam, fully ported '90 speed density TPI with '86 base so it fits older style heads, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
Won bracket races at Numidia Raceway with my '70 Nova
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
a bad launch will hurt a lot, by the same token though a good launch will help a lot. i run 14.2's at just over 94mph. most guys run that kind of et at least 2 full mph faster. but i get out of the hole better so i can get there just as quick with out having the mph. i am correcting the mph thing though
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
lata
tim
The V-6 had headers, flowmaster exhaust and a intake. It only had me by two car lenghts at the most.
Steve
1/4: 16.1@85.7
Steve
1/4: 16.1@85.7
The first 60' are the most important ones on the entire 1/4 mile. Fix your traction first, then add more power.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
<font face="Verdana, Arial" size="2">Originally posted by 88firebirdTBI:
</font>
</font>
Iroc8t8
May 4, 2026 08:09 PM
backtothe80s
Sep 5, 2015 12:39 AM
