what should i be running?
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
my times are in my sig. but should i be running faster? my mph 92.5 is greater than most of the people running 14.5's i know my 2.4 60ft doesn't help. the car grips and bogs horribly. i have 3.08 gears. what can i do to get better 60 ft times? all my launches were done around 3000rpms and a dump start. i tried 3500-4000 and it broke em loose and went every way but straight. how should i launch this car?
i feel that i should be running a 14.8 with the 92.5 mph. i live in oklahoma and the track i go to is about 1200 ft above sea level
thanks for the help
Andrew Peery
1987 IROC, 305 TPI, T5
Flowmaster, Ported Plenum, Accell plugs, Wires, Cap, and Rotor
All smog equipment gone and no cat
192hp and 265tq
15.20 @ 92.5 mph with a 2.4 60ft
thanks for the help
Andrew Peery
192hp and 265tq
this might help a little....not too long ago I kept getting paired up with an '88 IROC 305/5-speed at the local track and his best time was 15.2@88mph. His car was bone stock (from air cleaner to exhaust). My dad was taping us from the stands and i can see him smoking the tires off the line every single time. Maybe if you didnt rev so high at the start you would hook better. Try 2000 or 2500 rpms. I launch at 1500 with my 700R4 and my best was 15.3@88 with no tirespin, so with you should do a little better than me with your mods. I'm guessin 15.0 or very high 14's if you can hook.
1988 Pontiac GTA 5.0 TPI
-K&N Filter
-Hypertech Air Foil
-Hypertech Perf. Chip
-2.5in Flowmaster Muffler
-Catco Hi-flow Cat
15.32@88mph
2.077 60-ft.
Kills
94 Probe GT, 95 Mustang GT, 96 Impala SS, 85 Thunderbird 5.0, 95 Accord V6, 98 Integra VTEC, 70 Chevelle Malibu, CRX w/ Turbo and Intercooler (have it on tape to prove it)
-K&N Filter
-Hypertech Air Foil
-Catco Hi-flow Cat
15.32@88mph
2.077 60-ft.
Kills
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
If you cut a 2.0 sixty foot you'll have your 14.8 at least. Which is about right for 92 mph.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
try to ride the clutch out at 3000 or more RPM while not letting the tires spin but still hard on the gas.....Itll be kinda hard on the clutch but thats what a lot of manual racers do. the trick is to keep the R's up and tire spin down.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Car: 87 IROC
Transmission: 5spd
yeah my problem is not getting traction its avoiding the initial bog that i get because i hook way too good.
thanks for the help though.
Andrew
Andrew Peery
192hp and 265tq (at rear wheels SAE corrected)
[This message has been edited by smokin87iroc (edited April 17, 2001).]
Andrew
Andrew Peery
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
