Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
do the v-6 springs help very much for weight transfer....
Old May 20, 2001 | 08:13 PM
Z-BOSS's Avatar
I got a true radial efi class to run in this week end. I had some springs to try. Just wondering if they might be worth a tenth.
86 IROC 406 tpi mass air
trickflow g2 heads
slp runners
stock tpi
about a 272 custom hyd roller comp cam
30 lb injectors
no smog,a/c,or egr
working on homemade chip
running on radials....
Old May 20, 2001 | 10:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I put them in my car but can't give a comparisson since so much else was done at the same time. The only real way to say if the help or not is to do a swap at the track. Make a couple of passes with the original springs, then change them and make a few more passes. Runs made on the same day are the best way to compare changes. If you wait a week or 2 between races, weather and track conditions can change and give false readings.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old May 22, 2001 | 02:17 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Changing springs is nearly pointless without changing shocks. I seriously doubt you'll see any appreciable benefits without some shocks that will allow the suspension to operate like you want. Even a set of drag springs won't work well without the proper shocks.
Old May 25, 2001 | 11:40 PM
83 'Bird's Avatar
Changing springs is pointless unless ya change shocks? To a point. Tossing in a set of, say, Moroso Trick Springs wouldn't be pointless....would let your front end lift a bit more than stockers...regardless of whether or not you change your shocks at the same time. Granted a shock change would help launches even more, but aren't exactly necessary.
Old May 26, 2001 | 01:54 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
<font face="Verdana, Arial" size="2">Originally posted by QwkTrip:
Changing springs is nearly pointless without changing shocks</font>
Note the word, 'nearly'.
fbodyfreakls1
Oct 6, 2015 06:34 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
HikoriYami
Sep 21, 2015 07:11 PM
SG91camaro
Sep 5, 2015 10:27 PM
