Premium gas
<font face="Verdana, Arial" size="2">Originally posted by Alan84TA:
What is the advantage of running premium gas at the track in a low moded car. Will it actually effect 1/4 miles times?</font>
Good luck.
Mike L.
"If it feels good - stay in it
"1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, airfoil, Random Tech Hi-Flow Converter (soon to go byebye!). ALL STOCK otherwise.
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Car: '89 Firebird
Engine: 7.0L
As long as your computer isn't pulling back timing there is no advantage. With every day pump gasoline the higher the octane the less volitile the fuel. By using an octane level higher then what your motor needs you are making it more difficult to combust the air/fuel mixture and delaying the combustion process which will likely slow you down. Although, sometimes it's advantageous to delay the burn so that the pressure builds during the time when your crank is in a position to produce the best mechanical advantage. But with the state of tune and performance of average street engines you'll never notice the difference. Basically, use what you need and stop there.
[This message has been edited by QwkTrip (edited May 30, 2001).]
