Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
if my car would hook....
Old Jul 1, 2001 | 09:15 AM
86ZZ4's Avatar
based on MPH of 102.7,AND hooking,what do you guys think it would ET at?My AMX runs simalar MPH but it does 1.8 60's and only weighs around 2880 lbs.Best 60 ft i could manage in the Z is a 2.16 feathering the throttle for the first 30-40 ft.Did some more tuning and got MPH up 101 to 102.7,but still just died on the 60's.
86 z28 zz4 ssm lift bars ,3.73 simesed runners and a traction deficient 13.707@101.02,on a 2.16 60 ft on 295/50/15 junk street rubber ,best MPH run 13.82@102.7,69 AMX,390 4 speed sticky tires and other stuff..12.94@102.3
[This message has been edited by 86ZZ4 (edited July 01, 2001).]
Old Jul 1, 2001 | 11:08 PM
Basett_Racing's Avatar
I was running high 13.20 - low 13.30's at 102 in my 82 Z28. I had a totally stock suspension (even the front sway bar intact) on MT Sportsman Pros, and I was pulling low 1.90 60' times. I did pull a 1.88 only once, but it usually was around 1.91-1.93 If you get it hooking, you will definetly be in the low 13's. Since you some suspension mods,You may even be able to manage high 12's. 60' time is everything when getting a good ET. Proof of that is the fact that a great hooking, good weight transferring car with a LOT less HP than you can get 13.80's Get some good tires and she'll be rollin'!!
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
Old Jul 3, 2001 | 06:30 PM
86ZZ4's Avatar
yeah,if the tires never try to hook,the lift bars never get a chance to work
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
