Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What's the best way to launch off the line with a T-5?
Old Jul 4, 2001 | 11:09 PM
Jas89TTA's Avatar
I'm planning on taking my T/A to the track soon to see what it'll run, But what's the best way to launch off the line? I've been told to launch at 2700-3000 RPM's and other's say just let it out enough to keep the engine alive and then floor it. What way work's best? Also when shifting gears is it best to leave the gas pedal down when pushing the clutch in? Thanks, Jason
350 TPI, 5-spd, 3.73 gears, Posi-Rear, LT4 Hotcam, 1.6 Roller Tip Rockers, Accel Intake, Ported SLP Runners, Ported Stock Plenum, Ported Cast Iron L98 Heads, Coated Hooker Headers, 52mm Edelbrock Throttle Body, 24# SVO Injectors, SLP Cold Air Intake, Holley AFPR, LS1 Aluminum Driveshaft, Flowmaster Exhaust, Taylor Wires, MSD Coil,
Engine pic at http://albums.photopoint.com/j/Album...410&a=13413975
Old Jul 5, 2001 | 01:55 PM
Stormshadow GTA's Avatar
With all those mods if you power shift the T5 you will destroy it real fast.If you care about the tranny lay off the gas when shifting.launch around 2500 rpm
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Dynomax Super turbo Muffler
TB Coolant bypass
Old Jul 5, 2001 | 05:14 PM
84zeddd's Avatar
You did not say what tires you will be using
I would let the clutch out quickly just above
idle and squeeze the pedal to the floor with
street radials or dump the clutch at 2500rpms and mat it on a cheater slick or drag radial.Yes powershifting is hard on parts but damn it feels good when you nail a good clean pass.
Hope this helps
Old Jul 5, 2001 | 08:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The tranny isn't the only weak link. That cast iron pressure plate and flywheel won't like high rpm drops either. Aftermarket steel pressure plate and flywheel will last a lot longer.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jul 6, 2001 | 04:54 PM
Jas89TTA's Avatar
It's on street tires. So far the tranny is holding up, I Hope. Thanks, For the replies.
Old Jul 26, 2001 | 05:41 PM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
T-5's are stonger than people think...mine has lived through 3 cars mine running consistant low 12's to 12 flat(the others ran low 13's). Bring the RPM's up to 2500-3000 at the light, dump the clutch, wait for the tires to hook, then mat it. I was running 2.1 60 ft's last night on my way to 12.4's @ 117 using this technique on Pep Boys radials
Black 89 IROC...355, Solid Crower Cam, TFS heads.
12.0 @ 120.3mph with a 1.9 60ft...all motor
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Zane Story
Oct 8, 2015 12:40 PM
DARKmj16
Sep 9, 2015 04:07 PM
TBRays98
Sep 6, 2015 05:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
