Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
How does horspower transfer into 1/4 mile times?
Old Oct 26, 2001 | 08:35 PM
maksik7's Avatar
I'm wondering what kind of 1/4 mile would I run with an engine putting out approximately 300rwhp. The car has 3.08 Posi/700R4 and its is a loaded 89 TA/T-Tops. I am hoping for mid-high 13's, does that sound reasonable?
Old Oct 26, 2001 | 09:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
How much do you and the car weigh? It's a simple power to weight ratio but you must have a total weight of the car as it's going down the track. It's no good saying your car is only 3500 pounds when you may add an extra 150 to it.
ET will depend on how good your traction is. MPH is a better indication of how much HP is available.
Assuming around 3500 pounds total weight and around 300 rwhp, you should be able to run mid to high 13's if you can get traction.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Oct 28, 2001 | 10:02 AM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
Somewhere between 102 - 104 mph. ET will depend on traction, gearing, etc.
1989 Mustang LX 5.0 Coupe
13.34@106.7 - needs more gear and converter
1992 Mustang LX 5.0 Convertible
14.23 @ 95.something - 100% bone stock motor - it's been a while since I've ran this one
1993 LX 2.3L Hatchback - "The Ride to VCU"
Moderator Stangtec.com, SN95.com
Amelia and Nic's Twin Terrors
Old Oct 28, 2001 | 09:14 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Would 300rwhp put him closer to low
13s?
I'm pulling 13.5s right now, around 3600lbs
and I figured I wasn't stomping much more
than 280-285 to the ground.
-- Joe
Old Oct 28, 2001 | 09:41 PM
maksik7's Avatar
The car has 3.08 gears and has never been on a dyno, so 300rwhp is an estimate give or take 15hp. I'm hoping to get to the track before winter and I'd be happy with a 13.5-13.7 or so.
Old Oct 29, 2001 | 02:11 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
A friend with an '85 Z28 is pulling 300 rwhp on the dyno and ran a 12.15 at 109.6 mph last month. 300 rwhp is 350-375 hp at the engine, depending on if the tranny is an automatic or a manual. What have you done to the engine to get that kind of power?
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 29, 2001 | 10:10 PM
maksik7's Avatar
A friend of mine is considering buying the car (was me but I have no $$ ). The engine is a 350 bored 0.040 over with new heads, hotter cam, ported intake manifold, holley 750cfm carb, all the smog and AC removed, headers, full 3inch exhaust, bunch of other stuff I forgot.
I don't know the exact specs right off (the build sheet isn't with me) but the mechanic estimated it at 300rwhp so I'm going by that guess.
I think your friend isn't telling you something. I REALLY doubt that he would run a low 12 with 300rwhp... unless he has 4.11's and plenty of weight reduction. The new 300rwhp LS1's only run low 13's.
Old Oct 29, 2001 | 10:13 PM
NJ SPEEDER's Avatar
et has more to do with gearing and traction and mph comes from hp. look for an mph in the 100-102 range, with good traction that should net you a 13.5-13.0 range. your car may want a little more gear to do it's best.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Oct 30, 2001 | 02:16 AM
Violate 3.8's Avatar
If you have a good launch (~1.9) I don't see why you couldn't hit 13.5 or so. Just don't roach them off the line.
Old Oct 30, 2001 | 08:50 AM
Engine: 385 HSR
I know exactly what he has on and in his engine, and watched him dyno the other day. He pulled a 1.65 60-foot time on that run, and has boat-loads of torque and traction, plus 3.73 gears and a Vigilante converter stalling at least 2800 rpm. The LS1's don't have the torque, gearing, and traction he does.
Greg Westphal
'87 IROC 355TPI/A4
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
z28addict8490
Aug 7, 2015 08:48 PM
