Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
help i need a cage
Old Nov 7, 2001 | 06:05 PM
gummybr's Avatar
help i need a cage
I made it into th 11s (11.86 @114) two weeks ago now i need a cage does any body have any susgestions? like what kind of cage (6,8,10,point drop bars)?get it installed or do it myself? i know how to weld and have a welder
Old Nov 7, 2001 | 07:20 PM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
You have to have at least a 5 pt. rollbar. The doorbar on the passenger side is optional, but would be a good idea IMO. If you feel confident enough that you can do the welding yourself, then by all means save yourself a couple hundred and do it. I don't have access to a mig welder and only have minimal experience gas welding anyway so I paid someone else to build me a cage. $500 for a 6 pt. cage parts and labor. That ought to give you a rough idea on how much it should cost.
1989 Mustang LX 5.0 Coupe
13.34@106.7 - needs more gear and converter
1992 Mustang LX 5.0 Convertible
14.23 @ 95.something - 100% bone stock motor - it's been a while since I've ran this one
1993 LX 2.3L Hatchback - "The Ride to VCU"
Moderator Stangtec.com, SN95.com
Amelia and Nic's Twin Terrors
Old Nov 7, 2001 | 08:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Everything mentioned in the above post PLUS
now that you're in the 11's you need a 5 point harness, single layer fire jacket SFI 3.2A/1. A manual transmission car needs a scatter shield plus SFI rated clutch and flywheel. Screw in valve stems are required on all wheels with tubeless tires. Aftermarket axles are required with positive axle retention (ford 9", c-clip eliminators, rear disk brakes etc). You need a SFI Spec 18.1 harmonic balancer. Driveshaft loop is now manditory.
Welcome to the world of 11 second racing. Safety equipment requirements go higher in the 10's and a lot more is required in the 9's. Hitting the 9's gets real expensive.
I still run a 6 point roll bar in my car. It's legal to 10.00 unless you've modified the floor or firewall. Then it's only good to 11.00. There's nothing saying you can't put a full cage in the car but that's a lot of extra weight for a high 11 car. My 6 point roll bar is 70 pounds of mild steel. You may add enough weight to slow down to the 12's again.
The roll bar MUST be mig or tig welded. Any gas or stick welding will not pass tech inspection. Buy a rulebook and read all the requirements for bar positions.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited November 07, 2001).]
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
FueledSoul
Sep 30, 2015 09:18 PM
tmork454
Sep 29, 2015 06:33 PM
Bob88GTA
Sep 10, 2015 09:07 PM
