Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
My car!
Old Jun 8, 2012 | 10:12 AM
christian's Avatar
My car!
I never post on here but I thought I would share my junk! Car is a 83 trans am. It has been 9.43 @ 151 with a 1.55 60 foot. That was with a 80mm BW turbo. Car has a 355sbc, no intercooler, unported Edelbrock Vic Jr. heads, solid flat tappet cam, CSU blowthrough carb and now it has a GT4788 turbo on it and a Dart Lil M block. It just made 970WHP with 25 pounds on the dyno. The car is not a show car but I have not missed a race season or a cruise season in over ten years. The car including the whole turbo set-up, motor, trans, cage etc was all built by myself and my best friend! Thanks for looking!
Here is a vid of the car on the dyno two weeks ago!
http://www.youtube.com/watch?v=Y4Iy8...ature=youtu.be
HAHAHA I just read my signature, that tells you just how long it has been since I made a post here. I have had three turbo set ups since I had a nitrous motor in the car!
Old Jun 8, 2012 | 10:18 AM
christian's Avatar
Re: My car!
Las years motor pic!
On the street this year. I also own the 63 Acadian in the pic. It has gone 11.68 with a 235 drag radial.
Old Jun 8, 2012 | 10:58 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Re: My car!
2 questions......
Does that Giant Knock retard guage ever come in handy? lol
How much fuel pressure does a setup like that flow?
Old Jun 8, 2012 | 11:13 AM
christian's Avatar
Re: My car!
That is not a knock retard. It is a timing curve retard. It tells me when the msd box is taking timing out of the car once it has built enough boost to do so. The base fuel pressure is 7.5 pounds. There is a 1 to 1 boost reference fuel regulator that adds one pound of fuel pressure for every pound of boost so 25 pounds of boost equals 32.5 pounds of fuel pressure!
Old Jun 8, 2012 | 12:54 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Re: My car!
Thats pretty cool. So the MSD box will pull the timing on motor to allow the boost to come in on top of it. Seems fairly simple. I am using an XFI where you basicly lay the whole timing map out on a grid.
Old Jun 8, 2012 | 04:48 PM
DIGGLER's Avatar
Re: My car!
we have nearly identical motor setups... mine is a 358 with unported victor jr heads. 232/236 hydro roller cam, vic jr single plane with efi. its slowly working its way into the car now after sitting in the corner of the shop for 7 years.
what are you running for head gaskets?
Old Jun 9, 2012 | 09:06 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Re: My car!
nice! how's the down pipe run? how consistent is the car
Old Jun 9, 2012 | 09:53 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: My car!
3...2...1...
Lift-off!!
Nice!!
The dog came running in to see what was happening!! Lol!!
Old Jun 10, 2012 | 09:38 AM
christian's Avatar
Re: My car!
The car is consistent. It consistently runs way slower then it should. We will see what happens this year. I change have changed a lot of suspension stuff and we have far better track prep at our local track now. The down pipe runs under the motor mount. We notched the stock k member and from there the exhaust runs undereath the car like the normal 4" pipe routing!
Old Jun 10, 2012 | 10:00 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: My car!
Sick looking car! Those formulas make a sick looking drag car
Old Jun 10, 2012 | 10:30 AM
mw66nova's Avatar
Engine: 7.0L
Re: My car!
Do you have any pics of the downpipe?
Old Jun 11, 2012 | 08:57 PM
christian's Avatar
Re: My car!
Down pipe pic!
Old Jun 11, 2012 | 09:01 PM
mw66nova's Avatar
Engine: 7.0L
Re: My car!
thanks man! it didn't click that you're using a motor plate though....lol.
is that a 60mm jgs wastegate?
Old Jun 12, 2012 | 08:32 PM
christian's Avatar
Re: My car!
Yes it is!
Old Jun 13, 2012 | 12:21 PM
Shagwell's Avatar
Car: projects.......
Re: My car!
Nice set-up dude, some what "simple" for what it runs - I like it!
Old Jun 13, 2012 | 04:06 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: My car!
Nice!
One of Manitoba's fastest street cars right there!
Old Jun 25, 2012 | 12:27 PM
christian's Avatar
Re: My car!
Car went 9.19, 9.17, 9.15 and 9.06 @ 153 over the weekend for the win in Limited Street! I was told it was not a consistent car....I guess things have changed!
Old Jun 25, 2012 | 12:52 PM
DIGGLER's Avatar
Re: My car!
nice!! how did the 60's look?
Old Jun 25, 2012 | 02:30 PM
Shagwell's Avatar
Re: My car!
Solid times man - very killer set-up.
Old Jun 25, 2012 | 02:35 PM
christian's Avatar
Re: My car!
60 was 1.44 on the 9.06 and between 1.46-1.48 for the others. I was leaving soft! Lots more to go there!
Old Jun 25, 2012 | 02:36 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: My car!
Very nice!! Is this your car also? http://www.youtube.com/watch?v=rskTF...ture=endscreen
Mark.
Old Jun 25, 2012 | 05:58 PM
christian's Avatar
Re: My car!
Yes!
Old Jun 25, 2012 | 06:04 PM
mw66nova's Avatar
Engine: 7.0L
Re: My car!
lol, what is the story on that?
Old Jun 25, 2012 | 07:01 PM
christian's Avatar
Re: My car!
That is a huge car show/fun driving event that takes place in Brainerd Minnesota. It is called Powercruise. That was me getting second in the powerskid competition. It is basically a comp to see who can do the longest burnout without hitting the brakes at all. There is also a dyno comp, drifting, streetracing, car show and cruising all on an the Brainerd road course. It was by far the best three days of my life! It happens again this year from July13-15 and I will be there again!
Old Nov 9, 2012 | 10:15 AM
ihatemustangs's Avatar
Car: 74 z28, 89 IROC, 98 Z28, 91Z Vert
Engine: 383, 350, 347, 305
Transmission: th400, 700R, T-56, 700R
Axle/Gears: 3.42, 3.45, 4.10, 3.08
Re: My car!
I have been building a single turbo car, I like what u did, very nice
Old Nov 9, 2012 | 10:29 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: My car!
Nice car!
Old Nov 11, 2012 | 07:22 AM
87_TA's Avatar
Re: My car!
Very cool no doubt... Always a fan of the formula body style myself.
Old Nov 11, 2012 | 07:36 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: My car!
Very nice setup. I miss my 85 TA.
Old Nov 11, 2012 | 08:21 AM
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
Re: My car!
Awesome ride
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
