Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Is there any advantage to an auto?
Old Jul 6, 2012 | 02:15 AM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Whats better for racing purposes, an auto or manual transmission? The auto is heavier, and you cant control your shifts the same way. Although with an auto you dont have to be good with a clutch. I would assume for budget racing auto is the way because a turbo 350/400 is cheaper then a t56.
Those are just my thoughts, any ideas?
Old Jul 6, 2012 | 04:33 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Is there any advantage to an auto?
It's about consistency, an auto is way more consistent than a manual, and a good auto will shift quicker.....
Old Jul 6, 2012 | 05:16 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Consistency is in the driver and some on the equipment. I was knocking down consistency that was just crazy I thought for a manual.
The auto, but for running, will out shift a manual and the converter has the ability to hold a engine in its power band without dropping too low with the right converter.
I say auto for the track. Manual for the street car for the fun.
Old Jul 6, 2012 | 07:21 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Normally, the only time you see a manual transmission on the dragstrip is when the rules for your class state you have to run one. If you have the option to use an automatic, most people will.
I run a powerglide. I only need to make one shift. The less shifts you need to make, the more consistent you can be however it takes a lot more to stay in the powerband.
Old Jul 6, 2012 | 09:49 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Were assuming that the op is referring to drag racing. The auto also hits he tires a bit softer. Easier to hook up and launch, not as hard on the rear as dumping the clutch in a stick car. There's still a hardcore group of racers that love the stick. I build a few engines for an organization called Pro Stick. Those guys are nuts. Most of them run clutchless setups. Liberty, jeffco, gforce, etc. Then you have pro mod and pro stock...stickin with tha stick!
Old Jul 6, 2012 | 12:43 PM
Shagwell's Avatar
Car: projects.......
Most pro-mods are auto now as well. - Pro stock will likely stay stick/clutch for a long time, not only due to rules but because of being NA & utilizing high rpm.
No "H" pattern shifted manual can be nearly as fast or as controlled/precise as a typical manual valvebody racing auto is. Add to that the converter technology getting completely ludacris and the clutch manuals simply aren't the best option.
I would absolutely love a 3 or possibly even a 4-speed liberty in the camaro, but it's simply not logical even with the bruno-drive & converter.
A typical street car is more fun to drive with a manual, but a good auto will be faster & will be much easier to get the power to the ground.
Old Jul 6, 2012 | 12:49 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I will argue the softer hitting the rear tires statement. I used to think so, but there are slipper clutches designed for drag racing that actually adjust for the launch. There are some amazing parts out there.
Old Jul 6, 2012 | 06:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
A Lenco would be nice to have but at around $1000 per gear, it's a little pricey. When you look to see how a Lenco works, each gear is actually a planetary gear system similar to automatic transmission gears. Each gear lever is in one ratio or another. Neutral is another box at the end of the transmission. Technically, they're clutchless. You only use the clutch to start and stop. Once the car is moving, the clutch isn't used to shift.
Manually shifting an H pattern shifter while drag racing and pulling levers with a Lenco is comparing apples to oranges. Although they're both considered manual transmissions, that's where the similarities end.
The T5 isn't made for a lot of abuse. The T56 has 2 OD gears which are not required for drag racing. An older 4 speed or a Jerico would be the better choices for a drag racing manual transmission if you can't step up to a Lenco.
Old Jul 6, 2012 | 07:07 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
The t56 is a nasty street Trans, that for sure. A manual meaning manual shift is the limit to the clutchless racing Trans. Never seen one street driven.
Old Jul 9, 2012 | 11:06 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Axle/Gears: Moser 31 spline / 4.86
This guy showed up down here index racing with his stick car. Made it down to the semis of a 10,000 to win 6.00 index race, against all Automatic cars. On small tires too
Old Jul 10, 2012 | 12:19 AM
Car: White 84 z28
Engine: Chevy 350
I mean racing in general. If you have any info on other types, please share. In other types of racing the auto could be good so you can keep both hands on the wheel. But dont you want a stick for that so you can better control what gear your in going in and out of the forners?
Old Jul 10, 2012 | 04:40 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Consistancy. Very rare to see a manual car in bracket racing. Sure there are some out there, but its not a fluke why about 95% of bracket racers use autos.
Old Jul 10, 2012 | 06:14 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
The only time I would ever consider an auto would be for drag racing, any other racing, like street, autox, etc. I would use a manual.Automatics just annoy the hell out of me.
Old Jul 10, 2012 | 06:42 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
A regular auto, I agree. My th400, manual valve body, pro stick shifter....the fun is there.
Old Jul 11, 2012 | 07:59 AM
Shagwell's Avatar
I'm heavily considering a 3 speed lenco with a converter drive for the camaro. - The way the terms are being used in this thread that could be a manual or an auto, lol.
More and more lenco's are being used behind converter drives instead of clutch cans. It's not because of money or data in classes like pro-mod, it's because they are going faster.
Old Jul 11, 2012 | 08:10 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Manual valvebody Th400 to me is a clutchless manual Its awesome and best compromise for fun on the street yet having a solid built trans that wont break the bank. 1500 or less into a Th400 will hold 1000hp. T56 would need 3-4 grand to do that.
Old Jul 11, 2012 | 08:20 AM
Shagwell's Avatar
Reverse manual with a brake - only way to roll.
Old Jul 11, 2012 | 09:04 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yep, love the TH400 in the TA.
The T56...depends. I got mine for 900, rebuilt for 800, holds 750, i could upgrade the input and output for 600 more and hold the extra. Beyond that you are talking 150 plus HP applications if drag racing is the use, but for a street car, double OD is a blast and a mild rebuild like mine has lasted over 1200 RWHP. Traction on the street is just not available to bite and make that trans find its weak spot.
Old Jul 11, 2012 | 09:05 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
There any brakes with forward manual shift pattern? Mine is manual with forward shift but no brake and I kinda wanted to look into that with the new turbo setup. 8's is what I want and I need to launch to get there.
Old Jul 11, 2012 | 09:47 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I have all the respect in the world for your car. I just have to laugh at the fact that its not crazy to talk about street cars and 8 second time slips. It's awesome though.
Old Jul 12, 2012 | 07:33 AM
Shagwell's Avatar
Some, but it will still be a completely different vb so it won't save you any $ over a reverse pattern. - Once you try a reverse manual you'll never go back to a forward pattern. Having 1st gear right beside neutral & reverse is far more logical than a forward pattern.
Old Jul 12, 2012 | 08:08 AM
DIGGLER's Avatar
yup, my old trans was a foward pattern. with a tci outlaw shifter i went past 3rd and into neutral on a couple of occasions. now i have a reverse pattern with a cheetah shifter and its much much better.
Old Jul 12, 2012 | 08:34 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I just have that super popular B&M megashifter designed for these cars and its forward pattern. My trans came with a forward manual but if it has to be replaced, then so be it. Just thought I'd try to reuse it.
Not sure if the shifter can be used with the reverse pattern? I guess it should be 3rd gear would just be 1st gear right? It ratchets in both directions. I'd just need to relabel the shift pattern sticker so I know what gear I'm in
Old Jul 12, 2012 | 08:37 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Aint that the darndest thing? With todays technology and tuning, you can have 8 second streetable cars... Mines abit rough for a street car but I think it will do great once the tune is nailed down. It should have 8 sec potential. It certainly has the ingredients and guys have gone faster with smaller parts/lesser combos. It just sucks if I crack an 8, i'm still one of the slower cars around here 4-5th place sucks haha
Old Jul 12, 2012 | 01:42 PM
Shagwell's Avatar
Yes, most ratchet shifter cans be used with either pattern. - The reason you see different plates with standard type shifters is due to the detent methods(release trigger, etc) between gear changes. For example, the way a reverse pattern quarter stick detents you can push it from 3rd down to 1st in one hit, but on upshift to go from 2-3 requires squeezing the release lever; thus 1-2 made simply by moving the lever, 2-3 you have to squeeze the release.
Old Jul 13, 2012 | 03:14 AM
Car: White 84 z28
Engine: Chevy 350
Aint that the darndest thing? With todays technology and tuning, you can have 8 second streetable cars... It just sucks if I crack an 8, i'm still one of the slower cars around here 4-5th place sucks haha
Just curious who has the fastest street legal car on the board? And for that matter who's got the fastest track car?
But if your really that upset about being 4th-5th place, I'll trade you for my old lg4. That'll gain you ALOT of places!
Old Jul 13, 2012 | 08:56 AM
Shagwell's Avatar
I have one of the world's fastest garage-space-taker-uppers!
solid 4's @ 160ish in the 1/8, but been grudge racing so that's all I'm saying......lol
Old Jul 13, 2012 | 09:25 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
NO idea whos fastest...I believe the fastest I've seen is the guy with the big block with spray... almost running high 7's. 1BadRZ28 is his name i believe
Old Jul 13, 2012 | 01:45 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I have the reverse pattern th400 manual, it was easy to get used to, but was a blast watching the wife get used to it, lol.
Old Jul 13, 2012 | 07:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Certain shifters are used in different applications. Some people like a gate shifter, other a ratchet shifter. One of the more popular gate shifters is the Cheetah shifter made by Turbo Action. http://www.turboaction.com/shifters.html
With a ratchet shifter, there are many different styles and types. I currently use a B&M ProRatchet because the shifter handle always returns to the same upright position. Start in park and keep ratcheting back until you get to first gear. Keep pushing forward to ratchet and eventually you'll be right back in park. After you push or pull the shifter to ratchet it, the handle returns to the same position. I had a Megashifter and didn't like how the handle moved all the way forward when you put it in park. Once it was out of park, it worked like a regular ratchet shifter.
With a powerglide, I prefer the PRN21 shift pattern. Air or electric shifts work better when they push so it's better to push the handle forward. With the ratchet shifter, it's impossible to accidentally go into neutral since I only need to do one shift. Also after crossing the finish line, it's easier to pop the transmission into neutral as the car slows down so there isn't as much stress on the con rods as the car slows down. You shouldn't neutral a TH350 or TH400 though. Bad things can happen but a Powerglide is designed differently so it can be neutralled.
As for fastest street and track car on the board, it should depend on how they're making power. With today's technology and availability in power adders, it's easy to have a fast street car that uses NOS or a turbo because while driving around on the street, they're not making huge amounts of power all the time so it's still basically a street car. With my engine pushing around 1000 hp without a power adder, it's hard to consider it a street engine. I probably have one of the fastest NA cars on the board while there are even faster NOS/blower/turbo cars on here.
With a properly matched torque converter, a manual valve body and a ratchet shifter, an automatic transmission can be very precise on the dragstrip. Add in an air or electric shift from a timer or rpm switch and each shift can be made at the exact same time on every pass down the track. Banging gears through an H pattern manual transmission may be fun on the street and mandatory for road course and autocross racing but it's very inefficient on the dragstrip.
Even using a converter with a Lenco isn't really a manual transmission. The planetary gear system is essentially an automatic transmission that needs to be shifted manually so is it technically a manual transmission or not? The only disadvantage to using something like that instead of a true automatic transmission is the human error to shift the transmission. Miss the shift by a couple of hundred rpm and the run isn't the same. In a heads up race, it's simply whoever gets to the finish line first but the majority of us are bracket racers where consistency wins races, not speed.
Linson
Oct 24, 2025 02:00 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
djmarch
Oct 2, 2015 10:41 PM
Linson
Oct 1, 2015 09:50 PM
